Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-01-2008, 01:41 AM   #1
Default How Should I Frame this Single 10' Wide Step?
Hello, I had posted in the flooring forum about this question but was forwarded to post a thread about it here. I am laying down laminate on the first floor of my townhouse style condo which sits on concrete slabs. The dining and living rooms are 2 levels that are 2 steps apart, i.e., 2 steps down or up. I tore down a small 4 foot tall wall that split the two rooms and would like to create one step that is as wide as the room.
There is an existing step (made of concrete) on the floor which is about 12" deep, 5 1/2" tall and about 4 1/2' wide. I need to extend this step across the room so that I can Liquid nail laminate and stair nose onto it.
I have been told I should use concrete but I do not want to bond laminate on concrete that's fairly fresh. It doesn't seem like a good idea at all for moisture reasons. I also wanted to utilize the existing electrical wire/Romex (short wall had outlets) to make a wall outlet on the stair riser so wood seems like a better choice. I could route the wire through the framing.
My question to you is, what would be the best way to frame the step? Should I use a bunch of 2 x 10's cut and stand them up so that with the 3/4" plywood, they would create the right height of 5 1/2" to match the concrete step? Should I frame it another way? Should I destroy the existing step and frame the whole width of the room so it would be uniform throughout? How could I fasten everything onto the concrete? Utilize storm clips on the floor to mount the 2x10's? Should I use adhesive? I tore the wall down the other day and I'm at at a loss. Any help would greatly be appreciated it, thank you.
Here is the original thread I posted at the "flooring" forum. It adds extra details and info that may help you in getting a better idea about my situation.
How should I tackle this multilevel laminate project? Plus other questions.
Thank you very very much for your time and help.
Chris.
Chris' Place is offline   Reply With Quote
Old 04-01-2008, 02:59 AM   #2
It seems like concrete would be the way to go.I think if you drill and pin the existing concrete so the new step becomes one with the old, form out for the step and pour your concrete. It would be easier than building the step out of wood, then trying to fasten it to the existing step and floor somehow. As far as the moisture concern, Can't you make the step the last thing you finish so it has time to cure.
James Con is offline   Reply With Quote
Old 04-01-2008, 04:58 AM   #3
Originally Posted by Chris' Place View Post
Your wanting to continue the step shown,,,,,,Left of your pups shoulder,the one with the blue carpet backing? If that be the case I would use http://www.itw-redhead.com/trubolt.asp to secure a Pressure treated rim joist to the concrete. Frame out from there.
mark942 is offline   Reply With Quote
Old 04-01-2008, 08:34 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Forming an extension of the step with concrete would be my suggested method.
To a Newbi DIYer, this may sound intimidating, but it is actually going to be a relatively easy solution, secure, and proper.
As stated, you need to install rebar or pins, clean and rough-up the concrete to be attached to, etc, etc...
Can you use wood? Yes, PT with treated fasteners. Install cleats first, to attach the vertical segments to...etc...
- Gotta run off to work...
- Build Well -
Old 04-02-2008, 11:31 PM   #5
Dowel rebar in with epoxy and extend with concrete, like they said....
nadonailer is offline   Reply With Quote
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about attaching our wall to concrete. Since our wall will be sitting on concrete, there is a couple of different ways that we can attach our wall to that concrete. The... Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Installing an Anderson sash, without frame NateHanson Building & Construction 3 10-03-2007 07:28 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 07:29 PM
(urgent!) Covering/repairing damage on wooden door frame? Photinus General Discussion 2 07-19-2006 09:25 PM
Step by step Trishl Flooring 2 05-13-2006 12:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
