How Should I Cover This? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 10:35 AM   #1
DIY Expert in Training!
How should I cover this?
I am turning part of my garage into a home office. The outside wall has a 9"x3" course of block. I want to make it look very clean. My initial thought was to frame around it and drywall it. What do you folks suggest?
Oh yeah, the floor will be laminate wood.
gone_fishing is offline   Reply With Quote
Old 02-15-2009, 03:10 PM   #2
Drywall contractor
Rewards Points: 1,070
That's probably tour best option (remember treated wood where it contacts concrete or block), but you end up with a "dust ledge". Is it just one wall or all the way around?? If it's just one, you could frame a new wall and eliminate the offset. You wouldn't lose that much area. All four walls would be a different story. And actually, with it being at floor level, You would probably be better off covering it with wood (1x material). Less chance of damage, too much teouble to use corner bead which will end up getting bent or knocked off at that level........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Cover for Whole House Fan ntfspark General DIY Discussions 4 11-18-2007 01:57 AM
Patio cover Jackhammer Building & Construction 3 07-10-2007 04:49 PM
