Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-06-2012, 04:09 PM   #1
How to replace your clothes line
My wife and I moved in to a new house.... Together .... And while hanging laundry she found the exterior covering over the metal line to be cracked and missing.
Therefore my ears were ringing to fix it. So this is what I did...
First, I measured the distance between the two hanging poles, trees, etc and times it by two. Then you know how much new line you'll need to buy. I then bought the new line.
Then I cut the old line and removed it from the tensioner. Only remove the line from one of the wheels (pulley) that support the line in the air
I then put up a new hanger end that allows someone to move the line up and down for easy hanging and removal of clothes. Un bolt the top two bolts
Unbolt the bottom bolts
Then installed the new adjustable hanger and used the original bolts
Then I taped the new line to the old line that was still around the wheel (pulley) at one end
Then I pulled the old through until the new line came back to me. I ran the new line around the 2nd wheel until I had both new ends together. You'll probably have to cut the new line as it'll be longer then what you need...measure twice cut once
Once I had the new lines together I connected them into the original tensioner and turned the tensioner to spec (eye balled it lol)
Then it was all done
No more ears ringing
Fantastic is offline   Reply With Quote
Old 11-06-2012, 04:19 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Too much work.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 11-06-2012, 04:32 PM   #3
Originally Posted by gregzoll
Too much work.
It wasn't that much work lol
Main water line, meter to house ckc Plumbing 15 09-28-2012 10:15 PM
Need to Replace Main Water Line through Foundation rbperrie Plumbing 0 10-22-2011 01:58 PM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
