How To Replace Louisiana Pacific Siding With Hardie Plank. - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 08:25 PM   #1
How to replace Louisiana Pacific siding with Hardie Plank.
I need to replace several areas of the LP siding on my house. The bottom three boards are the ones that are bad and need to come off. I read an article on removing the old siding, but it didnt mention how to put the new ones on. Once I get the old boards off, do I need to start at the bottom and work my way up, or start at top and work my way down? If it matters, each board is roughly 10-12 feet long and 7-8 inches wide. Thanks!
emory is offline   Reply With Quote
Old 04-22-2012, 09:28 PM   #2
Rewards Points: 13,450
Is that the trash that looks like ground up newpaper when you cut it?
Good luck trying to remove it. It tends to mess up the piece above it your trying save when your trying to remove it.
I would start at the bottom and work my way up when installing the new.
How close to the ground is the bottom piece?
Old 04-23-2012, 08:39 AM   #3
Thanks for the reply. The house sits on a slab and it looks like most of them are 4-6 inches above ground level. Some of them look like they will just crumble off and the only the thing left will be to remove the nails that were attempting to hold them in place. Is there any particular nail I should use when hanging the new ones?
Old 04-23-2012, 10:18 AM   #4
http://www.hammerzone.com/archives/e...nt/install.htm
When it's that close to the ground concider doing what's shown in the pictures.
I believe even Hardee plank needs to be a min. of 4" off of any soild surface.
(it may be 2" but there is no 2" wide material availible to do what you need to do)
emory (04-27-2012)
Old 04-23-2012, 06:20 PM   #5
cortell's Avatar
Rewards Points: 504
I had to address a similar issue with a property recently. It was T1-11 LP SmartSide panel (4'x8' sheets). To answer Joe's question, it doesn't look like ground up newspaper. It looks like OSB, because it actually is OSB.
I had read reports that the OSB-based LP products (SmartSide) had significant failure issues prior to 1996, as the waterproofing treatment was applied solely to the surface. They have since changed their process such that every fiber that goes into the OSB is supposedly treated, and as such the siding is much less susceptible to rot. (Again, this is what I remember reading a while back). The siding that failed for me was installed around 1996 so it's possible I had the problematic stuff. It crumbled apart and it had 6" clearance from grade. However, what happened was that the bottom edge of the siding made contact with the concrete slab. When it rained and the slab got wet, moisture transferred to the siding and rotted it out over 15 years. That's my unprofessional analysis, anyway.
cortell is offline   Reply With Quote
The Following User Says Thank You to cortell For This Useful Post:
emory (04-27-2012)
Old 04-23-2012, 07:12 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
noLP is not Hardie is not Masonite
but your analysis is correct
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
emory (04-27-2012)
Old 04-23-2012, 07:23 PM   #7
cortell's Avatar
Rewards Points: 504
Yes. My mention of Hardie (instead of LP) was accidental, though I did it several times, so obviously my synapses were misfiring something fierce.
Old 04-23-2012, 07:27 PM   #8
cortell's Avatar
Rewards Points: 504
I got in the time machine and corrected my post, btw :-)
Tom Struble (04-23-2012)
Cheapest building materials TREX and Hardie Plank Dr.JUSC Building & Construction 0 08-12-2011 11:51 AM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 06:00 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
