How To Remove Window Sill? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 09:42 PM   #1
Rewards Points: 278
How to remove window sill?
I don't think this needs to be accessed from outside the house.
It seems like some kind of aluminum edges.
I want to remove it and replace with a thin one made the same as the countertop material. We will do some trim work around the window but want to keep the damage to minimum.
DIYGST is offline   Reply With Quote
Old 01-28-2010, 09:49 PM   #2
jlhaslip's Avatar
Rewards Points: 1,572
why not simply cover that one?
windows are usually attached from the outside. It would be easier to simply cover that sill on the inside.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-28-2010, 10:07 PM   #3
Rewards Points: 278
I don't know. I suppose a thin veneer would work, are countertop fabricators able to come up with a piece like that without charging too much?
I was able to remove the one in the kitchen but it was done with the formica countertop instead of this material
I suppose I should take off the quarter round there to see how thick I could go.
Old 01-28-2010, 10:35 PM   #4
Looks like a piece of flashing that's meant for something else. Remove the 1/4 round, in the middle slip a chisel under the part that hangs down and pry up. No turning back on this, you are going to ruin that flashing. My best quess would be that it's caulked underneath.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 01-28-2010, 10:53 PM   #5
Rewards Points: 278
yea, my whole house window with this same material.
Old 02-01-2010, 07:13 PM   #6
remodeling pro
Assuming you mean you will trim the window with jambs and casing:
I would remove all the quarter round (one of my pet peeves is this stuff used for inappropriate trim anyway), and carefully clean off any old caulking lines left on the window. Then fabricate a new sill from your chosen material and install it on top of the existing sill. Don't forget to leave the horns on the ends for the vertical casing to sit on. Fabricate and install the jambs, then trim with casing. The apron under the sill will hide the old sill. If the old caulking does not cleanup well enough, add a few shims behind the jambs to hide them.
troubleseeker is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 08:14 PM
