How To Remove Pocket Door (Stanley HW) - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 10:49 AM   #1
Rewards Points: 261
How to Remove Pocket Door (Stanley HW)
I hung the unpainted door in the track so I could check its travel and to have a convenient way to hold it for painting. It "snapped into" the wheel hanger assemblies. Now I want to remove the door so I can do the drywall. I've "unlocked" the white locking tabs on the hanger plates mounted on the top of the door, and given the door several good "tugs," hoping to "unsnap" it. No movement. How do I remove the door?
Curmudgeon10 is offline   Reply With Quote
Old 04-29-2010, 11:45 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
You need to reverse the 'snapping' process to remove them from their clips.
They can be tricky to remove, so be careful.
DM
Old 04-29-2010, 12:15 PM   #3
Rewards Points: 261
Is It Just Brute Force??
I've tried to reverse the snap in, but not wanting to damage anything, perhaps I haven't been yanking hard enough? Do the gray plastic tabs, which sit under the white locking tabs, have any role, i.e., do they need to be depressed, or held back while one yanks on the door?
Old 04-29-2010, 12:42 PM   #4
the Musigician
If you have a helper, have them raise the door slightly, then you take a flathead screwdriver and a small hammer to tap the clip off the holder.
DM
Old 04-29-2010, 01:05 PM   #5
Rewards Points: 261
I Removed the Door
Here's the way it worked for me: unlock by pulling white locking tab to the rear. Then hold gray tab (which is spring loaded) to the rear while pulling down. DO NOT FORCE or try and pry off --- you will damage the mechanism.
The Following User Says Thank You to Curmudgeon10 For This Useful Post:
DangerMouse (04-29-2010)
Old 04-29-2010, 01:31 PM   #6
the Musigician
Oh crap, I'm so sorry, I thought your title meant your NAME was Stanley, H.W.! Plumb forgot Stanley makes PD Hardware too.... LOL
I've been going with the assumption you had Johnson, since theirs is the only hardware I use.
Wow, my apologies. Thank You for posting the proper solution for the STANLEY Pocket Door Hardware.
DM
Old 12-16-2011, 08:27 PM   #7
Thanks... but I still can't get mine disengaged. The locking tab seems kind of useless. I pushed it back all the way... the same direction that I push the grey tab... lifted and jiggled the door but it's not coming loose at all.
Dan0 is offline   Reply With Quote
Old 12-16-2011, 10:48 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
If you have a very small mirror you can hold it up there and see what is holding it. The ones I have installed had a swivel clip you pushed back, pushed the door sideways, then let the door down.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-07-2015, 03:06 PM   #9
jfw
Rewards Points: 2
Re Stanley Pocket Door hw
I've been reading where some people had a difficult time removing / "unsnapping" Stanley Pocket Doors. Me too. The spring that holds the second (gray) locking tab is pretty strong and the tab is hard to get to. I got mine out by using a large bent needle nose pliers. With the white tab in the unlock position, you can place one side of the pliers on the second gray tab and the other on the side of the hangar plate. A good squeeze and the plate, with door, drops right off the hangar bolt.
jfw is offline   Reply With Quote
The Following User Says Thank You to jfw For This Useful Post:
oh'mike (03-07-2015)
Old 10-08-2015, 05:46 PM   #10
Rewards Points: 2
stanley pocket door release
Mine would not release. After disassembly, I found out why: the cams cannot be pushed far enough because the grey plastic wheel distorts under pressure from the metal spring. The head of the hanger bolt measures 0.450". The widest I could get the cams to open was 0.410". Poor engineering. I will repace it with an automotive type horseshoe clip. It may not "snap" into place, but it will have no plastic to deteriorate and disassembly will be self evident.
The Stanley hangers are brand new.
rt277 is offline   Reply With Quote
The Following User Says Thank You to rt277 For This Useful Post:
oh'mike (10-08-2015)
Tags
pocket , stanley
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
Installed pocket doors, now how do I remove the wood to install the hardware amdspitfire Carpentry 8 11-21-2008 01:43 PM
How do you remove a pocket door billangov Building & Construction 3 10-11-2008 07:26 PM
How to remove interior sliding (pocket) door Horst Remodeling 7 12-13-2007 12:13 AM
