Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-27-2005, 05:31 AM   #1
House to Home Maker
How to remove paint from brick
Hi All.
I have just bought a new house off-plan, and it seems like the builders were a bit careless with the paint. They've spilt some paint onto the bricks on the driveway, and no matter what I do, I can't get rid of it. Will I have to change the bricks? Here's what I've tried so far:
- Paint remover - Just took the top off the paint. Still quite a bit in the grooves and IN the brick
- Pool Acid - Was told this would bring the paint out. Didn't really work. Still quite a bitof paint IN the brick
Any tips would be helpful. Then I can put it on my Blog with tips that I've compiled on making a great home...
thanks,
James
beezee3 is offline   Reply With Quote
Old 12-27-2005, 07:37 PM   #2
I'm just stirring the:
CGofMP's Avatar
I had surprisingly good resultsd with a cheap pressure washer.
This worked for SOME paint spills but not for others.
Worth a try.
CGofMP is offline   Reply With Quote
Old 12-28-2005, 02:38 AM   #3
House to Home Maker
Hi,
Thanks. You know, I didn't even think of that. I have a little steam pressure washer. Maybe I should try that. Maybe pour some paint remover on the paint, and use the pressure washer to do a deep soak, high pressured, HOT rinse...
Thanks again.
James
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 07:14 PM
paint over brick ? marlenecapps@cox.net Building & Construction 2 10-29-2005 08:30 AM
