How To Remove Insulation Blanket Nails? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 07:43 PM   #1
Rewards Points: 236
Question
How to remove insulation blanket nails?
I am removing the builder insulation blanket in my basement.
It is nailed to the concrete wall using nails. They are hard to be pulled out.
Is there an easy way doing this?
Thanks!
Nick
325_man is offline   Reply With Quote
Old 12-26-2012, 08:00 PM   #2
Rewards Points: 236
here is a picture of one of the nails on the wall.
Old 12-26-2012, 08:12 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Smacking them with a hammer will usually break them off and you can hammer down the sharp edge at that point.
Don't bother pulling them out. You will do more harm than good.
If you don't go the hammer route, just an angle grinder with a cut off wheel will work.
Old 12-27-2012, 09:45 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
a back and forth motion will usually make it snap off, getting an accurate back and forth swing is paramount.
hand drive is offline   Reply With Quote
Old 12-27-2012, 09:48 AM   #5
Rewards Points: 236
I don't have a grinder . I tried hammer route and it seems that the type of nail they use is hard to be broken. I have been hammering in many direction for 30 minutes to a nail and it has not broken off yet. The concrete around it chips off
So, I pulled it out instead. I think I am going to do this way for the rest them Let me know if this is not a good way to do, and why.
Is it important that they are patched? (see attached picture) why?
It is about 2" x 2" in size and 1/2" deep.
Thanks again,
Nick
Old 12-27-2012, 09:49 AM   #6
Rewards Points: 236
Sorry, forget to attach the pix.
Old 12-27-2012, 10:17 AM   #7
AHH, SPANS!!!
in that case, get a gorilla bar and safety glasses... in some cases a metal abrasive saw blade can also be used on a skil saw,just would have to cut on an angle to reach the bolt where it comes out of the wall. get a few blades because once the blade wears down some it will not reach the bolt anymore because of the angle. Also,get a metal blade for a swaz all if you have one of those.
The Following User Says Thank You to hand drive For This Useful Post:
Windows on Wash (12-27-2012)
Old 12-27-2012, 10:58 AM   #8
You can twist them out if they want to come out that way.
Old 12-27-2012, 11:40 AM   #9
Rewards Points: 236
Do I need to patch the chip wall?
Old 12-27-2012, 12:19 PM   #10
Rewards Points: 216
go buy an angle grinder ! they are not expensive. easy to use. have a ton of uses. and will save you a ton of effort and time.
get several(pack of 10) cut off wheels, they are the skinny ones. and a few grinding wheels, the thicker ones.
you can thank me later.
Fix'n it is offline   Reply With Quote
Old 12-27-2012, 02:56 PM   #11
joed's Avatar
Rewards Points: 11,966
Assuming you are going to insulate again, leave them. They won't hurt anything to build a wall over them and insulate.
The Following User Says Thank You to joed For This Useful Post:
Old 12-27-2012, 04:01 PM   #12
+1
They are not structural issues and should never approach the full wall thickness.
If they are bothersome to you, you can easily patch them with a bit of crack filler or other masonry patch compound.
Old 12-27-2012, 04:37 PM   #13
+1 to that, one of the most useful tools I own, and they're fairly cheap
mterry is offline   Reply With Quote
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
i would like to remove old insulation from attic and start over with blue jean insulation in attic. My brother thinks this is a waste of time. I plan on pulling up old original boards and putting down new blue jean insulation followed by new plywoo waverunner Flooring 2 02-27-2011 08:07 PM
Remove spray foam insulation ruthiesue Building & Construction 3 08-31-2009 11:53 PM
How to remove old rusty raised deck nails win Carpentry 4 05-18-2009 11:30 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
