How To Remove/cut This Thick Metal Commercial Hood Duct? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 07:36 AM   #1
Rewards Points: 119
How to remove/cut this thick metal commercial hood duct?
This is the metal duct of a commercial hood that was over a gas stove. What is the best way to get it down? And what about those metal poles hanging from the ceiling that were holding up the exhaust hood?
How to remove/cut this thick metal commercial hood duct?-img_8016.jpg
SpaceCoast is offline   Reply With Quote
Old 01-31-2014, 07:41 AM   #2
DIY staff
Rewards Points: 7,174
Pull out the ceiling tiles---the threaded rods will unscrew---and the duct should have flanges with nuts and bolts---so a socket and a box wrench will be all that is needed to remove that----fairly simple job---
Windows on Wash (01-31-2014)
Old 01-31-2014, 08:18 AM   #3
Rewards Points: 12,868
Most likely also going to have to somehow cap that old vent off above the ceiling or you'll have an open hole to the outside.
oh'mike (02-01-2014)
How to seal around metal duct boxes in attic? Ocelaris Insulation 15 04-20-2013 06:09 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
flex duck vs metal duck fhammette HVAC 21 12-19-2011 07:30 AM
Hanging Ballet Bars (commercial environment) in metal studs 504branchie Carpentry 12 03-29-2011 09:45 AM
duct a range hood into garage? jimb317 General DIY Discussions 8 01-30-2008 08:41 PM
