How To Reattach A Towel Rod? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 11:26 AM   #1
Rav
Rewards Points: 552
Question
How to reattach a towel rod?
I have a light-weight towel rod, attached with adhesive to a tile bathroom wall, that has become unattached. The rod has been up for decades (since before we bought the house). I want to reattach it with a good-quality adhesive (drilling and anchoring into the tile is NOT an option). I've attached some pictures (the black stuff is the old adhesive which I would remove first). Would something like 3M 6004 Scotch Brand Super Strength Adhesive, or Loctite, be good things to use? Thanks.
How to reattach a towel rod?-cimg2582.jpg   How to reattach a towel rod?-cimg2583.jpg   How to reattach a towel rod?-cimg2584.jpg
Rav is offline   Reply With Quote
Old 08-18-2012, 01:07 PM   #2
DIY staff
Rewards Points: 7,174
Scrape off the old adhesive---use clear silicone caulk and tape for 24 or more hours---
Old 08-18-2012, 01:51 PM   #3
Rav
Rewards Points: 552
Follow-up question for oh'mike
Thanks for the reply, oh'mike. I happen to have "GE Silicone II Clear Silicone caulk for windows/doors/attic/basement." Will that work, or do I need a different type of clear silicone caulk? Thanks.
Old 08-18-2012, 01:54 PM   #4
the Musigician
DangerMouse's Avatar
Hold please, do not do that yet.
DM
Old 08-18-2012, 01:58 PM   #5
Rewards Points: 13,300
There is only one right way to do it and just trying to stick it back on is not it.
Like it or not it needs to be screwed to the wall.
If someone did not attach it were the studs are then use a toggle bolt.
Old 08-18-2012, 02:16 PM   #6
the Musigician
Just clarifying with Mike on the phone, be sure to clean out the "foam" (if that's what that black stuff is) and be absolutely sure you razor and clean off every bit of gunk on the tile before using the silicone.
It almost looks like there is already silicone on the right hand side, yes? ...and yes, we both agreed the GE (100%?) silicone caulk you have will work if applied as directed.
DM
Old 08-18-2012, 03:25 PM   #7
Rav
Rewards Points: 552
DM
Thanks, Mike and DM. I had already cleaned everything off with a razor blade scraper and then wiped with alcohol and rinsed and dried. And I've just applied the silicone caulk (yes, 100%) as directed, and will leave the tape on for at least the next 24 hours. And if that doesn't hold up I may have to find someone to do as Joe suggests (screw it to the wall through the tile). What's on the other bracket is what I used a number of years ago when the OTHER side detached, namely some sort of heavy duty mounting tape; this time, I wanted to consult at this site first.
Old 08-18-2012, 04:50 PM   #8
DIY staff
You should be fine--I've been hanging ceramic soap dishes and corner caddies with silicone for years and never had one come loose---
it will take some time for the silicone to set up because there is little air getting to that --so avoid using it for a few days---Mike----
Tags
adhesive , reattaching , rod , towel
Towel Warmer Above Tub rjschwar Electrical 2 05-12-2011 06:21 PM
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 08:02 AM
bathroom towel racks ramonakc Interior Decorating 5 04-19-2009 02:59 AM
Question on Hanging Towel Racks sbattisti Interior Decorating 13 02-17-2009 12:24 PM
Removing Towel Rack to paint bathroom bigbearok Painting 3 02-12-2009 06:40 PM
