How To Put Mud On Outside Corner For Second Coating? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-12-2007, 11:00 AM   #1
How to put mud on outside corner for second coating?
I have a question regarding muding on outside corner for second coating:
I know we need to run a 10" towel along the edge of a outside corner for second coating....
my question is:
Do I put the mud on the outside corner a portion at a time by a 5" mud knife and then run the long edge towel down a portion at a length,
or I put the mud on the outside corner for the full length with the 5" mud knife for a width of 8 to 10", then run the long edge towel down for the full length.
which way is better or the only way to do it... last night I did use the first way, and feel it is not too efficient...
KUIPORNG is offline   Reply With Quote
Old 01-12-2007, 07:13 PM   #2
Remodeler
MinConst's Avatar
I use the larger knife to apply the mud then smooth it out with the same knife. Unless my arm is beat from the days work then I sometimes cheat and use a smaller knife to apply. I think whatever floats your boat is the way to go.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 01-15-2007, 10:02 AM   #3
Thanks for the reply, but I probably didn't explain myself clear enough, I was asking should I apply mud for the whole length of corner or a bit at a time, before sweeping the long edge knife,
anyhow, I found out from the weekend experience, it should be apply to whole length or longest length you can sweep, then sweep it all with one stroke...
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
