Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-04-2009, 09:06 PM   #1
Default How to Polish edge of Marble ?
Am going to install marble countertop. Can I polish the rough edge of the block (approximately 1" thick) and if so, with what materials?
tedoldman is offline   Reply With Quote
Old 11-04-2009, 11:11 PM   #2
nap
You talking to me?
nap's Avatar
yes you can.
go here and watch the videos. To the right, there is one listed as DIY, I have not watched it so I cannot comment on it.
http://www.youtube.com/watch?v=brefiKR43vE
Old 11-05-2009, 12:35 PM   #3
Default tedoldman
Thank you!! The video tells me I can do it, how to and what tools needed. Guess I'll go ahead........
Originally Posted by nap View Post
yes you can.
Old 11-05-2009, 02:47 PM   #4
nap
You talking to me?
nap's Avatar
a few points.
take your time
use water whenever possible. It extends the life of the tools and helps to produce a better finish (obviously do not get into a situation where you are going to electrocute yourself.
use each level of grit long enough to remove all the scratches/grinding marks from the previous level of work.
Before you jump in. Read a lot and watch more vids. It is not all that hard to do but if you mess up a big ol' chunk of marble because you got into a hurry, you will regret it.
how about some before and after pics? This is one area we get a few inquiries about but I haven't seen anybody's before and after pics.
More On This Topic
Hi! My name is Danny and I am from Tampa, Florida and on behalf of Expert Village, I am going to show you how to use and maintain a bench grinder. Okay I am going to talk about the grinding wheels on a bench grinder. There is typically different grits of... Read More »
Hi! My name is Danny and I am from Tampa, Florida and on behalf of Expert Village, I am going to show you how to use and maintain a bench grinder. Okay I am going to show you now how to use the grinding wheel. This is the 120 grit so here I will be just... Read More »
Learn how to grind metal parts smooth when doing body work and restoring a car in this free DIY car-restoration video from our expert mechanic and body shop owner. Read More »
Hi! I’m William Myers with Subaru for Expert Village. We’ve checked your battery level, now if you had to add water to your battery all you would do is remove the cap and add your distilled water right in there. That’s how you would add... Read More »
Alrighty, then. We've got our handle attached. And, we're back outside and back to the angle grinder. Now, I've put another disk on this. This is a finer disk, so it's going to make a little smoother cut. And, I'm just going to grind down this a little... Read More »
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing 4 10-07-2009 12:49 PM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 08:09 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 04:10 PM
Tile over Marble??? RussellF Flooring 0 10-10-2006 08:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
