How To Mud Three Wall/ceiling Meet Corner? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-23-2007, 08:51 AM   #1
How to mud three wall/ceiling meet corner?
Is there a special tool or technique... I just use 6" knife and find the result is not too good.... compare upstairs those by the builders....
KUIPORNG is offline   Reply With Quote
Old 03-23-2007, 10:32 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
K,
We only coat one side of the corner at a time. Then, after these dry, we go back and coat the remaining side.
Where 3 corners intersect, we make it a point to coat the opposite side of each corner, so that they aren't meeting eachother....
Hope you can understand this...
- Build Well -
Old 03-23-2007, 10:51 AM   #3
I understand your part of coat one surface at a time... I did that for all the inside corners... but still when it come to the 3 walls corner... the knife have hard time reaching it.... may be that is what professional come to place, where it requires skill and patient....
Old 03-23-2007, 11:03 AM   #4
Yes, that 3 corner thing can be tricky...
- Build Well -
Old 03-23-2007, 12:06 PM   #5
Location: Cairo, Georgia (30 miles north of Tallahassee
Meeting of 3 corners: not a 3 way stop
Naw. Not as tricky as the meeting of 3 curved corners.
SouthGAreno is offline   Reply With Quote
Old 03-23-2007, 03:45 PM   #6
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Nor as tricky as an inside corner that comes together at 22.5 degrees and is 10' long and has to look straight!
Brik is offline   Reply With Quote
Old 03-24-2007, 12:51 AM   #7
That's what light switches are for....
- Build Well -
Two colors meeting in a corner jason29 Painting 2 05-01-2007 03:46 PM
How to put mud on outside corner for second coating? KUIPORNG Remodeling 2 01-15-2007 09:02 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
