How Much Mortar To Remove - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 08:23 AM   #1
How much mortar to remove
I'm using the Kerdi membrane in a shower renovation. I'm using Ditra unmodified mortar and Hardi backer. The first 2 pieces of Kerdi I put up didn't hold well because I didn't wet the backerboard enough. I've removed the Kerdi. Question is how much mortar do I have to remove for rehanging the Kerdi? Do I need to scrape down to the backerboard if it is adhering well?
hurtman is offline   Reply With Quote
Old 03-18-2013, 09:09 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
How much mortar (square footage) did you put up?
If it isn't much, I would remove it and get back down to the back board.
Old 03-18-2013, 09:32 AM   #3
It's about 36 square feet of coverage. What would you suggest- a scraper and sander?
Old 03-18-2013, 10:16 AM   #4
Scraper.
You don't want to be breathing in mortar dust. Not good for the lung health with the portland and/or silica.
Old 03-18-2013, 10:54 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Ditto on the scraper. You don't want to be breathing CBU dust either.
How much effort did it take to pull it off?
I've never used Kerdi, but I suggest doing a bit more research. My understanding is even if done properly, it will be fairly easy to pull off. You may be fine the way you were doing it.
Old 03-18-2013, 01:47 PM   #6
Rewards Points: 258
A scraper will work fine but I'd turn to my Fein MultiMaster with a blade made for removing mortar. My oscillating tool has become my favorite go-to tool. And prices for less expensive models are really reasonable.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 03-18-2013, 07:32 PM   #7
It's not coming off very easily. I think I'm going to do a redo with some of it still adhering. I'm not going to get it all down to the backerboard.
Old 03-18-2013, 09:09 PM   #8
Rewards Points: 236
its been a few years sinse i used kerdi. but back then they said to only use regular drywall.
Fix'n it is offline   Reply With Quote
Mortar Color segal Concrete, Stone & Masonry 8 02-11-2013 08:49 PM
Toilet won't sit all the way on floor bsmith6356 Plumbing 23 02-03-2013 08:29 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 11:13 AM
How Do I Remove Mortar From Porcelain Tiles? C_J_GO Flooring 5 09-06-2009 10:42 AM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
