How Much Does Wall Paper Removal Cost - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 03:56 AM   #1
Post
how much does wall paper removal cost
I want to remove the wallpapers from one room and move it to the other. Is it true as told here : http://www.fixr.com/n.wall-paper-removal.west-roxbury.ma.html that it would cost me around 300 $.
teddy123 is offline   Reply With Quote
Old 04-26-2009, 09:21 AM   #2
LeviDIY's Avatar
Rewards Points: 252
I've only ripped down wallpaper with no intention of saving it... its not difficult, just quite time consuming and frustrating... you're costs will be almost all labor... and to save it, probably a lot of labor.
LeviDIY is offline   Reply With Quote
Old 04-26-2009, 11:56 AM   #3
Rewards Points: 678
I agree with LeviDIY, it would be a lot of labor. Re-hanging it would be tricky when it comes to making the seams look perfect. If the individual strips of paper stretch even a little bit when they're being removed or re-hung, the pattern will be difficult to match at the seams.
It mostly depends on the quality of the paper and how well the walls were prepared before the paper was hung. There's a product called 'wall size' or 'wall sizing' that can be painted on the walls before the paper is hung. It allows the paper to be removed later in full sheets and with no damage to the walls.
Your link leads to the index of this forum, so we're not able to see what you want us to read. Could you try again? That would help.
It must be very special paper, I really hope this works out for you. Good luck.
Do you know approximately when the paper was hung, how old it is or the manufacturer?
gma2rjc is offline   Reply With Quote
Old 04-26-2009, 07:08 PM   #4
Drywall contractor
Rewards Points: 1,070
I'd like to see that happen!! And for $300.00???? NO WAY...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Though the wall vent removal philiplouis HVAC 1 07-13-2008 06:50 AM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Tar & Felt paper removal bhc65 Roofing/Siding 3 02-28-2007 03:12 PM
