How To Mount 2x4 To Masonry Wall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 12:16 PM   #1
How to mount 2x4 to masonry wall?
Hello everyone,
What is the best way to secure this 2x4 to the cement wall?
Anchor screws, tap screws etc...
If tap or anchor, do I need to remove the 2x4? Right now it's being held up with liquid nails.
Thanks!
helpmelearn is offline   Reply With Quote
Old 06-12-2010, 12:29 PM   #2
Drywall contractor
Rewards Points: 1,070
You can use "Tap Cons" and leave it in place.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-12-2010, 12:52 PM   #3
I have some Tapcon screws (3/16" x 2-1/4"). When I drill the Tapcons into the 2x4, the screw doesn't penetrate the cement wall. The screw begins to go right through the 2x4 and the tip of Tapcon just doesn't want to go in the concrete wall.
What am I doing wrong?
Old 06-12-2010, 01:28 PM   #4
Drywall contractor
You should pre-drill the 2"x4" with a wood bit and then you must pre-drill the concrete with the appropriate size Tap-Con bit (look on the box for size). The screw is not self-tapping....
Old 06-13-2010, 10:25 PM   #5
jschaben
Rewards Points: 502
Smile
bjb's got it right. You want to drill a pilot hole through the wood about the same size as the tapcon threads. You don't need the tapcon biting into the wood. Then go in with the tapcon bit and preferrably a hammer drill. The tapcon bit will be slightly smaller, 3/32 if I remember right, to get a pilot hole into the masonry for the tapcon to bite on. The hole in the masonry needs to be slightly deeper than the penetration of the tapcon. in your case, looks like about an inch into the masonry should be about right.
Good Luck
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
How do I mount this 60's bathroom wall sink? Roy Rowlett Plumbing 7 05-12-2011 01:36 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 02:59 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
How to mount cables on masonry wall without conduits? dave.murphy Electrical 5 01-24-2007 05:19 PM
