How To: Measure For Replacement Window - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-16-2010, 08:05 PM   #31
Rewards Points: 174
Originally Posted by kwikfishron View Post
Sounds good to me, you’ll have to buy me a plane ticket if you want a guarantee.
were talking these measurements need to be exact down to a 16th of an inch, right - I'm going to go measure a few more times
tb582 is offline   Reply With Quote
Old 04-16-2010, 08:14 PM   #32
kwikfishron's Avatar
Rewards Points: 348
A 1/16” doesn’t exist in window measurements. If you give them a measurement to the 1/8” what you’ll probably get is a window a 1/16” either way.
kwikfishron is online now   Reply With Quote
Old 04-16-2010, 08:47 PM   #33
Rewards Points: 174
revised numbers are 32x45 5/8 - I checked them 10million times and this is what I'm going with.
Old 04-16-2010, 08:59 PM   #34
Rewards Points: 348
Cool, even if your wrong a ¼” or so it will only cost you a hour or two of frustration but by the end of the day, “mission accomplished”
Old 04-16-2010, 09:05 PM   #35
Rewards Points: 174
lol if only it was that easy... as I think I alluded to in a previous post, is the window sill and the stool all one piece?
I would like to replace at least the stool but taking a second look at the sill makes me think its seen better days. While it doesn't seem rotten or soft perhaps if its just as easy to replace both?? do they make a simple 'kit'? (I have limited tools so routering edges of the stool would be tough)
How to: measure for replacement window-img00001-20100416-2201.jpg
Old 04-16-2010, 09:21 PM   #36
Rewards Points: 348
There is no "one diy kit fits all" that I khow of.
Yes, all the brown part (in your pic.) is ugly but if it’s "not rotted" then most of it will disappear when your new window butt’s up to the white and will cover all or most of the ugly. While the old window is out you will have the chance to sand, paint, or replace anything that you would otherwise have to attack from a ladder since you now have the opening clear.
Old 04-16-2010, 09:24 PM   #37
Rewards Points: 174
Yes, all the brown part (in your pic.) is ugly but if it’s not rotted then most of it will disappear when your new window butt’s up to the white and will cover all or most of the ugly. While the old window is out you will have the chance to sand, paint, or replace anything that you would otherwise have to attack from a ladder since you now have the opening clear.
Right, so I think the sill will probably be fine as you said it will be covered by the new window... What about the stool, is that something that can be bought or do I need someone with wood working skills to 'create' one. Since it looks like the stool is seperate from the sill, I suppose I could take off the stool and use it as a template and use my rotozip for the round edges then a sander to smooth out?
Old 04-17-2010, 06:27 AM   #38
Rewards Points: 348
I your going to replace it then yes, yes, and yes.
Old 04-28-2010, 12:15 PM   #39
Rewards Points: 174
I'm getting nervous now, my new windows should be here Friday morning.... This may be another stupid question but what keeps the new windows (besides the screws in the side) from falling right out? ??
Old 04-29-2010, 07:45 PM   #40
Rewards Points: 174
just got word that the new windows are here... any list minute advice? or an answer to the question above?
Oh and also what type of caulk is used between the outside stops and the new vinyl window?
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
replacement basement window - how to measure? qchawkfan General DIY Discussions 9 01-20-2010 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
