How To Keep 2x4 In Place When Spanning 2 Studs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-23-2014, 07:16 PM   #1
Rewards Points: 150
How to keep 2x4 in place when spanning 2 studs?
So I need to run 2 2x4s horizontally between studs to support the shower valve and pipe for shower head. How do you fasten these down without them moving?
If you want these 2x4s in a specific place when you go to hit a nail through them it pushes them out of position.
Arsinek is offline   Reply With Quote
Old 01-23-2014, 07:20 PM   #2
DIY staff
Rewards Points: 7,174
I usually use a screw---sometimes I will use my finish gun---but usually a screw---
Old 01-23-2014, 07:31 PM   #3
Rewards Points: 150
Do you drill a pilot hole? How do you drill a pilot hole with the board moving?
Old 01-23-2014, 07:35 PM   #4
Rewards Points: 712
A 2x4 block screwed to the studs for your horizontals to rest on will usually make it easier. Being you are a DIYer invest in a couple quick grip clamps. They are like having an extra pair of hands.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (01-23-2014)
Old 01-23-2014, 07:46 PM   #5
Rewards Points: 150
Ah, that might work. I do have one quick grip and using it crossed my mind but I didnt think of having it clamp on a wood block.
The Following User Says Thank You to Arsinek For This Useful Post:
Old 01-23-2014, 07:53 PM   #6
Rewards Points: 712
Just use the clamp to position the blocking while screwing it to the studs as Mike mentioned. Bore a pilot hole in the first member the screw will slip through. DIY ers know that sometimes good things take a little longer.
Old 01-31-2014, 08:35 AM   #7
Rewards Points: 1,442
I've built soffits using nothing but screws and my bare hands. If you put enough pressure on it the wood stays in place. You can also make it a very tight fit that you have to hammer into place. That will usually hold it. It's a pain. Clamps def would help.
mikegp is offline   Reply With Quote
Old 01-31-2014, 09:01 AM   #8
Rewards Points: 13,300
A few other suggestions. Just set the 2X on the floor to predrill it. Sometimes I'll use a drill a hole the size slightly larger then the size of the head of the screw then finish with one the size of the major diameter of the threads on the screw. insert the screw in the drilled hole before setting in place.
Or use a Kreg tool.
Old 01-31-2014, 09:52 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
If you are concerned the 2X4 will move forward while screwing, draw a line where you want the face of the 2X4 to stop, drive two small nails on the line leaving about an inch of nail sticking out, the nails will stop the 2X4 so it will be in the perfect spot for the valves. If you have a kreg jig you can pocket hole the screws.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Reinforcing Weakened Studs rjschwar Building & Construction 12 04-04-2011 12:11 PM
heavy shelves, metal studs... themikeindy Carpentry 2 03-28-2011 10:36 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 07:59 PM
Patching drywall-where to place seam? AllGoNoShow Building & Construction 6 09-20-2006 12:02 PM
