How To Install Vinyl Of Existing Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 03:40 PM   #1
how to install vinyl of existing siding
I just purchased a house with wood clapboard siding. The paint is starting to peel and I also think it is lead based. I dont want to hire someone specialized in removing the lead paint so i wanted to cover it with vinyl. How do i go about doing this?
jgreen2121 is offline   Reply With Quote
Old 03-10-2010, 07:56 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.. Buy the siding,+ start hanging it...
Bondo is online now   Reply With Quote
Old 03-10-2010, 08:47 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
Tom Struble is offline   Reply With Quote
Old 03-10-2010, 11:23 AM   #4
Household Handyman
Rewards Points: 1,408
Come on now guy's! Just "buy and hang" probably won't work in this case. The current siding is "wood clapboard", but what is the vertical run (distance from one board's bottom edge to the adjacent board bottom edge) as compared to the proposed vinyl? Unless this was an exact match--you will have the nailing edge (top) of the vinyl sitting on the clapboard with some edges set-back and some edges standing proud. This will create a "ripple" effect on the vinyl when viewed from either side. IMO--I would nail "furring strips", 1x2's, vertically on 12" centers to nail the vinyl to. This is a good time to add the 3'8" rigid foam insulation to the exterior, it will help the "R" value some. Also--when using this method, there will be gaps at all edges between the vinyl and original siding. Be sure to seal all gaps created by placing vinyl on strips, over clapboard. David
Old 03-10-2010, 12:14 PM   #5
cool now you told him everything he needs to know to side his house
Old 03-10-2010, 04:57 PM   #6
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
I would never think of hiring a professional
to do it.
After all,its protecting the biggest investment
most of us ever make in our life.
Since minor leaks can cause severe and unseen damage
over time,the little bit of advice you receive on a
DYI site could end up costing more than getting
someone with experience to do it in the first place.
There's a lot more detail that needs to be addressed,most
learned after years of experience.
oldfrt is offline   Reply With Quote
The Following 2 Users Say Thank You to oldfrt For This Useful Post:
HomeSealed (03-11-2010), Tom Struble (03-11-2010)
Old 03-11-2010, 09:08 AM   #7
aww common ...it can't be that hard
almost everone that owns a pickup truck can do vinyl siding
Old 03-11-2010, 09:18 AM   #8
ccarlisle's Avatar
If anyone can do it, then it's also true that few can do it well.
Each of us have our own standards but it'd suggest the OP go to www.vinylsiding.org and read the .pdf 44-page installation manual to better his chances.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following User Says Thank You to ccarlisle For This Useful Post:
Old 03-11-2010, 03:55 PM   #9
that's good advice..sorry for being flippant
Tags
siding vinyl
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 07:27 PM
installing full frame windows with existing siding mlmaher Building & Construction 3 09-11-2008 08:56 AM
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 07:45 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
