Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-11-2011, 10:36 PM   #1
How to install a stand up shower.
I have searched for videos across the web to help me with a predicament I have found myself upon. I can't seem to find any answers so now I find myself registered to this forum. It seems to be full of helpful people and I just hope some one finds it in them to take their time to help. I am currently remodeling my entire bathroom. I have started from scratch... New flooring, walls are almost done and I can't get the rest of the bathroom done until I solve my problem first.
Problem: I bought a neo angle standup shower base. When I went to see how it would look on the corner of my bathroom I noticed the walls are not exactly squared. The entire surrounding walls are going to be tile and I'm getting a glass door. I just don't know how to fix the gap which extends to almost an inch and a half (Pictures coming soon if I'm not able to upload any right now from phone). If any one has questions about my walls this is what they consist of:
I have added insulation between the studs in addition to insulated foam sheets ( I'm turning into an energy saver). Then I have the osb( I think that's what that pressed wood looking plywood is called) sheet. I bought the cement sheets that I will put up for the tile to go to and then the tile. ( currently tile has not been bought to as I am so indecisive as to what color and texture and size.) the back part of the wall has a different kind of sheet. The guy that was building my bathroom said I could use some of the hardiplank that I already had bought before to use as my siding for the house. Idk. I'm kinda iffy on the thought, but it's already there. someone please help me. It's the only bathroom in the house and I need to finish it soon.
Diy.Ana is offline   Reply With Quote
Old 10-11-2011, 11:06 PM   #2
Tileguy
Bud Cline's Avatar
You've got some real issues there and you are pretty much off to a bad start all around.
Hardi-plank is not used for shower walls. Hardi does make a product named Hardibacker for shower walls.
The first thing to do is to straighten the walls somehow.
The guy that was building my bathroom said....
So where is this guy now and did he have a hand in building the crooked walls?
The Following User Says Thank You to Bud Cline For This Useful Post:
Diy.Ana (10-12-2011)
Old 10-12-2011, 12:05 AM   #3
He is not longer helping cause he doesn't have time well Its just one wall which has the hardi plank so I guess I'll take that one off. I did buy hardi backer. So I'll replace that one once the wall is back to specs. Ok destroying is my thing. I'm sure I can manage tearing that wall once more. Now problem solved. I know know to start the wall from scratch. Now to find a good carpenter
Old 10-22-2011, 01:06 PM   #4
Stuck in the 70's
Blondesense's Avatar
First of all let me say I'm no expert. Just someone who went through something similar. With your shower base did you get the whole kit, walls, door and all, or just the base?
If it is just the base I would suggest you thoroughly research how you are going to complete it before you proceed. Also research the costs involved. This is not something you want to have to figure out as you go along. Making this work may very well cost you more in money and headaches as purchasing a complete shower kit.
Old 10-22-2011, 03:09 PM   #5
I'm a little confused what was done and why
Why is there a finished floor and no drain for the shower?
Why is there OSB on the walls? OSB has no place in a bathroom
Why are the walls up before the plumbing has been installed?
Are you putting in magic pipes?
The out of square walls are the least of your problems.
Consider yourself lucky the contractor decided he doesn't have time to finish this.
Did it seem a little odd to you that a contractor starts a job and then leaves in the middle due to "scheduling problems"?
You need professional help with this bathroom. The fact you allowed all this to transpire shows me you don't really have a clue as to the sequence of the project, what materials to use, or how they are supposed to be installed.
If this was an extra bath, with no time pressure, you could go along at it at a slow pace and we could guide you along. I don't think this can happen in your time constraints.
Ron
B. Franklin 1759
Old 10-22-2011, 10:06 PM   #6
Tileguy
Bud Cline's Avatar
So what's it been now? About two weeks? I would consider the OP MIA.
Old 10-23-2011, 09:01 AM   #7
It takes time to find contractors who put the plumbing in before the floors and walls.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Bud Cline (10-23-2011)
Old 10-23-2011, 09:04 AM   #8
LOLOLOL
Joeychgo is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 10 01-25-2010 11:01 PM
Install DensGuard over DensArmour for shower? lk55 Kitchen & Bath Remodeling 1 01-13-2010 09:52 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 09:36 PM
