How To Install Replacement Window In 2x4 Frame? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:23 AM   #16
Ok I got it...Thanks.
Do you recommend using 2 bys for the frame or 1 bys? Earlier on you said the same as the existing R.O. or something like that. Did you mean 2 bys? Just seems like 1 bys would work will for the frame.
BFD8 is offline   Reply With Quote
Old 01-07-2009, 12:19 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
i would use probably 5/4 for the window frame. its an existing rough opening right?
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 12:46 PM   #18
Yup. Thanks for all the info, I hope to get to it this weekend if people don't keep coming up with other things for me to do.
Old 01-07-2009, 12:56 PM   #19
good luck
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 06:17 PM
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
basement window replacement ponch37300 Building & Construction 3 08-12-2008 04:58 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
