Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-06-2009, 11:34 PM   #1
How-to install glass tile over metal of fireplace? Pix attached.
1x1 glass tiles on a mesh backing - to be installed over the metal of my 3-sided fireplace - what to use to adhere the glass tile?
At one time I had found on the web rolls of double faced sticky stuff designed for tile installation - but I cannot find it now...
Suggestions?
thx!
Vince
How-to install glass tile over metal of fireplace?  Pix attached.-dscn0764.jpg
Old 03-07-2009, 06:57 AM   #2
Remodeling Contractor
Glass tiles get their color from the backing. You need an adhesive to mount to metal, but best to check what the manufacturer of that tile recommends.
Old 03-08-2009, 04:24 PM   #3
I think you're missing an important point here.This is a theoretical tile installation over metal that will get very hot. This metal is light guage and has no rigidity what so ever.
You need another plan or be ready to waste both time and money on a project that will not work.
Ron
Old 03-08-2009, 09:07 PM   #4
Ron
Actually the outer surface gets just somewhat warm to the touch even with the gas log on high - there is an inner liner that takes the heat of the fire. And the metal mounting area appears to be quite solid - no flex or deflection.
Old 10-02-2009, 03:48 PM   #5
Did you figure out how to tile the metal part of your fireplace. I have a similar situation with my wood burning fireplace. I want to put glass tiles on top of the metal part? Anything would help.
Sally10
sally10 is offline   Reply With Quote
Old 10-02-2009, 04:07 PM   #6
you can use refractory cement. this will handle the heat and is available at any mason supply yard.
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
How can I install a Soffit?? pics attached Hammiamm Roofing 6 12-04-2008 10:05 AM
what color of paint and tile for fireplace? sil Interior Decorating 1 09-28-2007 05:23 AM
tile install bids oldno7 Flooring 1 10-02-2006 04:33 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
