How Hard To Level An Old Apron Tub? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 09:08 AM   #1
Cool
how hard to level an old apron tub?
I have two older kohler cast iron apron tubs- in good shape & working well for more than 15 years. We are redoing the tile surround to accomodate new plumbing.
The tubs are about 1/4 to 1/2 inch out of level, and seems they have been since first installed, because original tile was scribed to accomodate the
slope. One tub leaks a bit at the front edge, possible because of the slope
towards the room.
How hard is it, to shift & level these tubs?
The general contractor is very "leery", i guess is the word, to try and change these, but I can't really understand why. The drains are disconnected, the wall are down to the studs, and the tubs are just resting on a couple crippled studs at the back wall. We've removed the wall in adjacent closet to remove the drain & waste, and I can see the feet of the tub and all the way to the other wall behind the apron.
Is there really a big difficulty here?
We've begun picking up a lot of slack on our project because the general is having some health issues, and I'm less & less confident his answers are based on construction issues vs his inability to do the work. I need a referee on this question so we can decide whether this is something we can do.
Thanks,
Eileen
astersia is offline   Reply With Quote
Old 01-13-2008, 09:37 AM   #2
Rewards Points: 5,326
With the tub as you describe it, it is basically a "new" install. There's no reason you can't reset the tub.
Ron
Old 01-13-2008, 09:31 PM   #3
Thanks for the reply. We'll figure something out.
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 09:38 AM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 09:59 AM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
How to get string level? AllGoNoShow Carpentry 7 10-05-2006 01:30 PM
