Originally Posted by abefroman
How hard is it to change locks/tumblers?
Is it easiest to just change out the locks? How hard is it to find 4 locks, 2 deadbolts, 2 handles, with the same key?
TIA
You'll need to buy them & bring them to a locksmith if you want them all the same. You can find door locks etc that may match at hardware store. They will have codes on them, if the codes match they use the same key
That said I find it better to have different keys for front, back & basement. If I need someone to have a key &/or key gets lost I only have to change out that lock
Most are fairly easy to swap out
