How To Go About Replacing Fireplace Surround? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 11:28 AM   #1
Rewards Points: 304
How to go about replacing fireplace surround?
Hello,
The next project I have is to fix/replace the fireplace surround. I had wood paneling all along the wall (of course it was glued on) that was removed, and the drywall is damaged so I'm replacing the drywall. After removing the paneling however, the issue is that the tiling around the fireplace now stick out further than the wall, so it needs to be fixed/replaced.
I have since removed the tile surround, and found that the black fireplace surround part (with the mesh type "screens" for the fireplace) isn't actually plumb with the wall, and juts out further than the drywall (at the top). The fiureplace is actually a wood burning fireplace with a bump out and chimney (chimney is wood with siding and ducting for the fireplace). I cut a piece of the drywall above the fireplace to take a peek behind, and you can see it's open and see the inside of the exterior bump out section.
Any ideas/suggestions what would be the best way to go about fixing the fireplace surround so it's flush with the drywall? Can I simply unscrew it in some spots and "reseat" it further back so it's flush with the drywall? Also, should I add insulation behind the drywall above the fireplace, because there's a cold draft that comes right in when I cut out a piece of the drywall? I'll post a picture of how the surround is jutting out later today. Thanks!
How to go about replacing fireplace surround?-img_8980.jpg   How to go about replacing fireplace surround?-img_8979-1-.jpg
NewHomeDIYGuy is offline   Reply With Quote
Old 01-26-2012, 12:20 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by NewHomeDIYGuy View Post
...After removing the paneling however, the issue is that the
(edit: non combustible material used to separate the fire source)
around the fireplace now stick out further than the wall...
...so it needs to be fixed/replaced.
a) it doesn't need to be fixed or replaced
b) removing it may create other problems
Old 01-26-2012, 12:27 PM   #3
Rewards Points: 304
I don't understand your response..? I don't want to entirely remove the fireplace surround (as obviously something need to exist), but I want to fix it so it cosmetically doesn't look like ****.
The metal fireplace surround is not plumb with the drywall after removing the moulding and tiling, and sits out about a half an inch or so next to the drywall. Are you suggesting I leave it as is, and just tile around it and shim it wherever necessary? I'll post a picture up when I get home.
Old 01-26-2012, 12:34 PM   #4
This is exactly the situation that trim is made for...
Minich is offline   Reply With Quote
Old 01-26-2012, 05:12 PM   #5
Rewards Points: 304
Ok, if trim is the way to do it, then I'll do that. I was just wondering if there was a better way to get the fireplace surround flush with the drywall. I'm going to be replacing all the drywall on the wall. If not, so be it. Here are the pictures I promised. The fireplace is flush at the bottom, but as it rises it protrudes out about a 1/2" at the top. I guess when I retile it I can use some extra mortar to fill in the gap at the top and sides, and trim cut carefully to follow the contour and hide the imperfections in the fireplace? Thanks for the help.
How to go about replacing fireplace surround?-20120126_164836.jpg   How to go about replacing fireplace surround?-20120126_164844.jpg   How to go about replacing fireplace surround?-20120126_164934.jpg   How to go about replacing fireplace surround?-20120126_165038.jpg
Old 01-26-2012, 05:52 PM   #6
MarginallyQualified
Some tile might look nice there too.
Old 01-26-2012, 07:51 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
The bottom front needs to be shimmed up, that will kick the top back. You may have to trim some of the sheetrock off at the top to get the front to raise up. Code says wood can not be closer than 8 inches from the sides of the firebox and 12 inches above. Every inch you come away from the wall with wood, you will need to go an additional inch away from the fire box.
Shimming the front may cause a gap at the bottom but that is easy to hide.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
NewHomeDIYGuy (01-26-2012)
Old 01-26-2012, 09:12 PM   #8
Rewards Points: 304
Big thanks for that response! I'm completely unfamiliar w/ code for fireplaces, which is why I proposed the question here. You're the first person to give me a detailed and clear response. I haven't ripped out the drywall from the entire wall (it's going to be replace anyway) and tried to see if it could be shimmed/etc. easily, simply because it's cold here and there's a cold draft that comes in once I open up the wall, but I might just have to do it. The thing is, the top of the fireplace surround is actually shimmed with wood shims (it's hard to tell in the picture). So, perhaps if I remove them it'll straighten out? I'm not sure why this was done, but I guess I need to see what's behind it first.
Are the fireplace front/surrounds usually framed with 2x4's on the sides and top, or are they just resting in place without any support behind? Thanks again for the help!
-Mike
Old 01-26-2012, 09:21 PM   #9
Rewards Points: 304
That's the plan.
Old 01-26-2012, 10:56 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Mike in the houses I built we framed the walls like any other wall with 2X4s and installed a header over the firebox mainly so the mantel could be installed easily. There are cripples over the header to the ceiling also.
Jim
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 02:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 05:37 PM
Added new Fireplace Surround need drywall tips rocketdoctor Drywall & Plaster 2 12-06-2009 07:14 AM
Replacing and repairing a tub spout in a tub surround westhawk Plumbing 2 08-10-2009 03:07 PM
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 10:16 AM
