How To Get Rid Of Barcode On The Edge Of Wall Tile? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 12:21 AM   #1
Rewards Points: 33
How to get rid of barcode on the edge of wall tile?
I recently had new porcelain tile installed in my bathroom. I have an outside corner where 1 edge of tile is visible and 1 of the tiles has a barcode printed on it. Would it be possible to sand the barcode off without causing any problems? If so, what should I use to sand it?
The other option is to get some paint and paint the exposed edges of all the tiles, but I'm afraid that it would be difficult to get a clean paint line while keeping it out of the grout.
CubsWin is offline   Reply With Quote
Old 05-12-2013, 01:18 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 2,950
Pictures speak a million words.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 05-12-2013, 01:24 AM   #3
Bill Kearney
Rewards Points: 1,146
Porcelain tile with an exposed edge? No bullnose or schluter strip edging?
wkearney99 is offline   Reply With Quote
Old 05-12-2013, 02:16 AM   #4
Rewards Points: 520
This was my thought as well. Somebody didn't install this properly...
Seattle2k is offline   Reply With Quote
Old 05-12-2013, 07:11 AM   #5
Rewards Points: 3,082
Try some Acitone. (finger nail polish remover will also work)
CubsWin (05-23-2013)
Old 05-12-2013, 10:05 AM   #6
Rewards Points: 258
If the acetone does not work you might want to stop into your local hardware store and pick up a diamond grit sanding sponge and give it a rub. To finish off that edge I would probably lay down a bead of silicone.
fixrite is offline   Reply With Quote
Old 05-20-2013, 03:03 PM   #7
Rewards Points: 81
Denatured Alcahol, or acetone, or MEK (my favorite)
one cut is offline   Reply With Quote
Old 05-23-2013, 09:26 PM   #8
Rewards Points: 33
This worked perfectly. I bought some pure acetone and the ink came right off with an old rag. Thank you!
The Following User Says Thank You to CubsWin For This Useful Post:
mae-ling (05-23-2013)
Old 06-01-2013, 11:05 PM   #9
Lord of Slums
Rewards Points: 1,116
Now lets move to the plumbing fittings. How about the metal supply lines that are chrome. Those stickers will not come off those lines. Oh, that made me so mad
mj12 is offline   Reply With Quote
Tile shower surround meeting sheetrock on wall? forkandwait Kitchen & Bath Remodeling 3 03-01-2012 10:57 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Wall tile - five questions CZ DIY Tiling, ceramics, marble 4 04-24-2010 01:44 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 03:16 PM
