Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-02-2010, 12:05 AM   #1
willowgirl's Avatar
How to get nails out of basement floor. Is there some kind of trick?
I'm in the process of cleaning up after a flooded basement and the nails in the floor are driving me crazy. I had a flood a few years ago and ripped the floor up and walls out etc. But the many of the nails didn't come up. Its not a basement that's used but really want to get the nails out. It makes it difficult when something like this happens to clean it. Is there a trick to getting the nails out? They are in good really difficult to get out.
willowgirl is offline   Reply With Quote
Old 03-02-2010, 03:11 AM   #2
sdsester's Avatar
What type of floor? Make sure you have a good strong nail puller? If you don't care about the floor since the basement isn't used much? You might think about just cutting/grinding them flush with the surface. A little grinder will make short work of the whole process. Watch the sparks near gas appliances like the water heater and furnace though.
sdsester is offline   Reply With Quote
Old 03-02-2010, 06:50 AM   #3
Super Moderator
Concrete nails are hardened--they will usually just snap off of you hit them from the side.
Then borrow sdster's grinder an clip off what's left. (if you don't own a 4 1/2' grinder-they are cheap-and very useful)--Mike--
Old 03-03-2010, 02:21 PM   #4
just hit them from side to side this will snap them off but getting rusty nails out is not good fun most will snap any way.
martin.rayner3 is offline   Reply With Quote
Old 03-03-2010, 04:46 PM   #5
wear safety glasses they will take your eye out
The older I get the better I was
Old 03-03-2010, 08:40 PM   #6
willowgirl's Avatar
I will for sure, thank you
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 09:31 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Liquid nails - which kind? DIYGST Building & Construction 10 11-26-2008 05:50 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
