Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-02-2013, 07:50 PM   #1
Question
How to fur wall on a Concrete and Wood Wall?
I'm attempting to finish my basement. One unique aspect to the basement is that the garage is located in the basement. On the wall that has the garage door, there is a steel beam that runs over the garage door. This beam extends into the area that I plan the finish. The area below the beam is framed with wood studs atop a 2 foot concrete foundation. That wall extends beyond the beam and in that case it is a 9 foot concrete foundation wall.
So my question is how to fur out around this wood concrete hybrid wall. The exterior framed wall currently has batts insulation. Also how do I handle insulation? On the other interior walls I plan to use fiberglass batts with a membrane.
mklein49 is offline   Reply With Quote
Old 01-02-2013, 08:25 PM   #2
Got a picture?
Old 01-02-2013, 08:26 PM   #3
Sure, give me a second...
Old 01-02-2013, 08:39 PM   #4
I'm currently working on the other side of the basement, so I forgot I have all the junk that was stored in the basement along that wall.
The picture just shows the top. Hopefully, that's enough to give an idea of what it's like. You can see where the beam is run at the top and the pocket it sets on. Also, you should be able to see the top plate of the wall.
Old 01-02-2013, 09:23 PM   #5
MJ Force's Avatar
It looks like you could frame out a new wall over that section. Allow for the bulkhead on the left. You could use 2x3 studs. If you have to notch a few studs around beams shouldn't affect the integrity of the wall.
Does that make sense? Or am I missing something in your picture.
MJ Force is offline   Reply With Quote
The Following User Says Thank You to MJ Force For This Useful Post:
mklein49 (01-02-2013)
Old 01-02-2013, 10:02 PM   #6
No that's essentially what I've been thinking. I wasn't sure if some special needed to be done. I also wasn't sure how to handle insulation.
Old 01-02-2013, 11:33 PM   #7
MJ Force's Avatar
Of course you'll have to anchor the top plate, of the framed wall, to some addition framing or backing in the joist above. (Not sure of your level of carpentry so I added this)
If it was me I would have foam insulation sprayed in after the framing. Or follow your local building codes regarding insulation. (Vapor barrier etc.)
I had my basement spray foamed and it keeps the room very dry and warm.
Tags
concrete, finish basement, insulation
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Framing a wood studded wall against a concrete block wall miamicuse Remodeling 7 04-25-2012 09:23 AM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
