Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-14-2013, 04:04 PM   #1
How to float tile over hot mop water proofing?
I recently had the base of my shower waterproofed the hot mop method. I did not realize that floating tile over the asphalt would be a bit challenging.
A contractor told me to just put the deck sand in there. But the product manufacturer mentioned I might want to put lath in to strengthen the bed. What do you guys think?
Also I am planning to use thinset to get the lathe to stick to the shower side of the shower curb. Thinset will stick to asphalt, right?
darsunt is offline   Reply With Quote
Old 01-17-2013, 12:01 PM   #2
nope, it won't - nothing will stick to asphalt in this instance,,, having screw'd down expand'd wire mesh would've been a good idea but too late now,,, IF it were mine, i'd rip it out & d-i-o ( do it over ) the right way,,, curious why you felt it necessary to have it hot-mopped - is this outside ? try redguard
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Sump Pump Water Level w/inside Drain Tile scott j Plumbing 1 02-18-2011 11:25 PM
using on demand water for a heated tile floor Al Hibbard Flooring 0 09-27-2010 04:06 PM
Water Damaged Ceramic Tile DoubleTrouble Flooring 4 06-12-2010 03:17 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
