Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-09-2009, 02:50 PM   #1
How to fix warped header?
I'm adding a 48" set of doors to an opening that used to just be open. After getting the doors set in place I've realized the header is warped into the bedroom about 1/2". I know I could just cover it up with trim, but is there any way to fix it w/out replacing it?
bigburb is offline   Reply With Quote
Old 06-09-2009, 04:07 PM   #2
Moderator
If non-bearing, just saw cut 3/4"+ the way through it from the concave side and nail or screw it straight. Add a backer if needed.
Be safe, G
Old 06-09-2009, 05:02 PM   #3
It is load bearing.
Old 06-09-2009, 06:25 PM   #4
Moderator
Was it load bearing before? With a header in the joist space above?
If you installed it, just replace it. I don't see how you could trim it, going into a room. Even taping the joint to wallboard would expand and contract with the seasons differently, and show. If you are adding a bedroom, please make sure you have egress (escape) from that room out a required window for safety. Be safe, G
Old 06-09-2009, 06:41 PM   #5
It has always been load bearing, the opening has always been there, I'm just putting a set of doors. These doors are going between a bedroom and an existing bathroom that originally had the vanity just open to the bedroom.
Old 06-10-2009, 12:14 AM   #6
Chisel
Mop in Hand is offline   Reply With Quote
Header in a "modern brace" framed house jtpwils Carpentry 14 11-18-2008 09:24 AM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 09:55 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
