How To Finish A Basement With Low Air-ducts? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 11:20 AM   #1
MKW
How to finish a basement with low air-ducts?
The basement air ducts are under the ceiling. It looks like this:
This makes the basement shorter/lower, and I am guessing it would be impossible to finish the ceiling because of the air-ducts being in the way.
Is it possible to move the air ducts into the ceiling, by craving a way trough the wood beams, or would that be dangerous for the stability of the flooring above? Could you tell me how to move the air-ducts into the ceiling so I can finish the basement. Also how much would it cost to hire someone to do this?
Thank you.
MKW is offline   Reply With Quote
Old 09-13-2012, 01:37 PM   #2
MKW
Anyone?
Old 09-13-2012, 01:49 PM   #3
MKW
I found this: http://www.familyhandyman.com/DIY-Pr...space/View-All
Old 09-13-2012, 02:20 PM   #4
as long as it carries the same amount of airflow it should be ok. is it worth the cost for those few inches rather then boxing them in like they usually do. most basement i have been in the ductwork was usually kept on one side or the other so you had at least one half you could finish.
Old 09-13-2012, 02:24 PM   #5
MKW
Hi Danny,
Thank you for replying.
That's the problem, they put the duct-work all over the basement. Is it suppose to be done that way?
Old 09-13-2012, 02:56 PM   #6
Newbie Bill
Rewards Points: 522
Most of the time, yes. Sometimes they can contain the ductwork within the joist bays, sometimes (as is the case with most trunk lines) they have to run those below the bottom of the joists.
Mainly because cutting into the beams and or joists to place your HVAC ductwork would create some major structural issues.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-13-2012, 11:25 PM   #7
Rewards Points: 2,212
Have an HVAC guy look at it and see if they can be run better. If they are against a wall you can box them in and they are out of the way.
If you really want to go nuts get rid of them and use electric heat!!!
mae-ling is offline   Reply With Quote
Old 09-14-2012, 12:37 AM   #8
Rewards Points: 13,978
And to ansewer one of your questions, no way can you cut into any floor joist for any reason that much.
Old 09-14-2012, 01:05 AM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by MKW
Is it possible to move the air ducts into the ceiling, by craving a way trough the wood beams,!
Absolutely not!
Absofreakinlutely!!!
Frame out around the duct and rock it.
sublime2 is offline   Reply With Quote
Old 09-14-2012, 07:23 AM   #10
MKW
Thank you everyone, for replying!! I truly appreciate it!
I like this option! And someone said I could put bulkhead over the ducts, put some lights in it, and make a feature of it.
Could you guys give me an estimate of how much it will cost to re-arrange the ducts to the edge of the basement?
The basement is not that big to begin with, and with the ducts going everywhere, it makes it much smaller than it is.
Not only that, but the furnace is right in the middle of the basement. I think the previous owner had that installed about 7 to 9 years ago. It looks like this:
So now you understand, why I want to at least move the ducts out of the way. It's really disorganized if you ask me, the way they were put in. I wonder why they didn't put it around the edge of the basement?
Old 09-14-2012, 09:51 AM   #11
Rewards Points: 150
One thing that would help in getting an answer is this:
What would you accomplish by rearranging the ductwork (wether it's metal or flex)? In other words, what are you trying to do here?
oodssoo is offline   Reply With Quote
Old 09-14-2012, 10:41 AM   #12
We actually removed the soffits on our ductwork to expose it when we took the center wall out, also exposing the beam and posts. Painted the beam and posts black and patched the ceiling. The ductwork showing bothered us much less than the soffit hanging down. It works if you don't mind that more industrial look.
Pianolady is offline   Reply With Quote
Old 09-15-2012, 06:39 AM   #13
Not so new
12penny's Avatar
Rewards Points: 520
I started using metal for soffits years ago and never looked back. Straighter, cheaper, lighter and easier.
12penny is offline   Reply With Quote
Need more space, time to finish the basement. Thoughts? GingerMan Building & Construction 10 07-09-2012 08:22 AM
Basement Finish - Soffit Against Poured Concrete InDashMP3 Remodeling 16 04-10-2012 09:18 AM
correct order to finish basement diy001 Remodeling 2 03-09-2012 01:04 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
Want to finish basement mopared Remodeling 3 02-20-2005 04:49 AM
