How To Fill Gap Between Wall And Cabinet? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2008, 05:17 PM   #1
Question
how to fill gap between wall and cabinet?
i just floated out the kitchen wall so it's level with the outer corner support "bracket" a previous owner put on. now i have a narrow gap between the wall and kitchen cabinet. the gap varies but is no more than a quarter-inch wide (horizontal), and it's about 3 feet long horizontally. how do i fill this gap?
thanks for the help!
AmandaRuth is offline   Reply With Quote
Old 07-19-2008, 05:57 PM   #2
Rewards Points: 2,906
It's hard to understand exactly what the problem is without being there to see it. However, is it possible to buy a straight wood molding, stain and varnish it to the same colour as your cabinets, scribe the wall profile onto that molding, cut the molding along the scribe line, fit the molding against the wall, and then nail it to the cabinet?
Nestor_Kelebay is offline   Reply With Quote
Old 07-19-2008, 10:29 PM   #3
Registered User
Termite's Avatar
Another option (if you don't want to add a piece of moulding) is to caulk the gap. First, use a putty knife to fill the gap with foam backer rod. Backer rod is kind of like a flexible foam dowel rod. It is sold in rolls, usually near the caulk. It will fill the gap and will give you something to caulk against. It should be no more than about 1/8" deep in the gap...That way you don't have a huge thickness of caulk in there.
Next, use masking tape on the cabinet to protect the wood from the caulk. I go right to the edge of the wood, leaving none of the face exposed.
Then run a bead of caulk in there. Wet your finger and use it to form the caulk into the joint and remove the excess. A damp sponge can be used to "tool" the joint.
Remove the tape immediately before the caulk skins over.
Once the caulk is dry, re-mask the cabinet and paint the caulk the same color as the wall. It isn't perfect, but will hide gaps so they don't jump out at you.
Old 07-24-2008, 12:03 AM   #4
thanks for your advice. i'm going to go for caulk since the gap width varies from 1/16th to 1/4th.
what's the correct order to finish the wall: prime, caulk, paint? or caulk then prime?
Tags
drywall , mud
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 09:14 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Question on wall construction wood warrior Building & Construction 1 04-24-2008 11:25 AM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
Wall oven smaller than Cabinet Space kdiangson Appliances 4 11-13-2007 09:21 PM
