How To Fill In Corner? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-28-2008, 09:53 AM   #1
How to fill in corner?
What should I use to fill in the gap created by the rounded corner of the tub (see red area in crude drawing below)? What about the seam between the green board and cement board? Should thin-set be used with fiberglass tape?
cooper4x4 is offline   Reply With Quote
Old 08-28-2008, 04:21 PM   #2
Registered User
Termite's Avatar
Is the cement board oriented vertically, applied to the wall? I'm having a heck of a hard time picturing where the gap is. Any chance you could post a photo?
Old 08-28-2008, 05:33 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
your going to use thinset and mesh tape to spackle your seams so fill the void with thinset.
Old 08-28-2008, 05:44 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yep, like buletbob said: mesh and thinset.
- Build Well -
Old 08-28-2008, 06:53 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 896
Yep! Mesh and thinset. Much stonger than drywall mud.
Sir MixAlot is offline   Reply With Quote
Old 08-28-2008, 10:52 PM   #6
yep, as advised above
this is much easier than a risky scribe cut on the backer board.
Big Bob is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
