How To Fill A 61" Bathroom Space With A Vanity? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 06:10 PM   #1
Rewards Points: 682
How to fill a 61" bathroom space with a vanity?
Is it normal practice to custom order a vanity to fit, if you want it to run from wall to wall in a bathroom (mine is 61"). Or is there another way it is usually done?
darsunt is offline   Reply With Quote
Old 02-25-2013, 06:13 PM   #2
Rewards Points: 682
Perhaps I should look at it the same as installing kitchen cabinets?
Old 02-25-2013, 06:22 PM   #3
Rewards Points: 13,274
Lot of options.
You can find one close and build out the wall.
Buy cabinets and add filler strips on the ends and use a soild top custom cut to fit.
To name a few.
Old 02-25-2013, 06:22 PM   #4
Rewards Points: 12
We just did 2 bathroom renos with 60" cabinets. They were full height custom cabinets (Just like a kitchen). You could get standard cabinets to fill 60 inches and add a 1/2 filler on both sides.
djlandkpl is online now   Reply With Quote
Old 02-25-2013, 11:05 PM   #5
Rewards Points: 940
I recently did a bath vanity which was very close to 40". I made a cabinet, then put a tile top on it. I used 36" of 3" tile, then two 2" strips of glass accent tile to get me to the 40".
You can feel free to make the cabinet a bit small, maybe 1/4", and make the facing the exact size, then take a 1/16th at a time off it to get it in tight.
I used urethane grout and I grouted against the tiled wall, but you can use sanded caulk if you prefer.
cleveman is offline   Reply With Quote
Old 02-26-2013, 06:35 AM   #6
Davejss's Avatar
Rewards Points: 740
If its a high-end remodel all our cabinets are custom built. If its a lower cost job we use stock size pre-made units with fillers.
Davejss is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Bathroom vanity on top? Smudgeboss Flooring 8 10-27-2011 11:39 AM
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 09:39 AM
Bathroom vanity rough in diyer4162 Carpentry 13 11-09-2007 06:36 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 10:10 PM
