Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-25-2007, 08:30 PM   #1
How to drill 6-8" hole in reinforced concrete?
I think I might've posted about my problems with my septic tank before. I just spent 3 weekends digging out a magnolia tree that someone planted on top of the septic tank in the home we just bought. It was a ton of work. I didn't think i'd ever see the septic tanks.
I've dug it out and can see the lids of both tanks but they're at least 4 inches of reinforced concrete that has to be lifted off. I want to make an access hole in both lids so that I don't have to dig this thing up again.
Is there a masonry tool that I can rent to do this? Does it have any problems cutting through the rebar? Is it difficult to operate?
Thanks.
Jemo is offline   Reply With Quote
Old 02-26-2007, 10:27 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Call someone that does core drilling.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-26-2007, 02:36 PM   #3
When was the last time it was cleaned out?
redline is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 11:06 AM
