-   -   How do you take old fireplace brick to new cement board? and framing questions. (http://www.diychatroom.com/f15/how-do-you-take-old-fireplace-brick-new-cement-board-framing-questions-67379/)
KlamathMog 03-22-2010 06:34 PM
Hello everyone,
I tore out some old masonry and it left behind some poorly mounted sheetrock and some uneven brick. I want to have a 12" tile border around the fireplace opening with a wood trim mantle around that (so the tile doesn't need to be flush to the sheetrock at all). I will have finished sheetrock above the mantle.
Issue 1: Mounting sheetrock to the wall- there is a 1"+ gap behind the sheetrock. I can feel a stud horizontal in the middle of the rough sheetrock panel, so I am going to need to add some more structure there. What do I add? Non-flammable framing? Like steel? What is the best way to tie them into the vertical framing outside the fireplace?
Issue 2: Getting Hardi-backer on the uneven brick. I need to level the surface around the fireplace opening and mount hardi-backer to it. I was thinking I would do mortar in a few layers with some chicken wire to reinforce it and prevent it from running down, and then fasten the hardi-backer on with masonry screws after drying and sanding flat.
Suggestions? Code violations?
This is in Portland, Oregon.
EDIT: the bricks that look like vents are NOT vents. They can be removed.
http://i7.photobucket.com/albums/y25...y/DSCN3128.jpg
http://i7.photobucket.com/albums/y25...y/DSCN3127.jpg
http://i7.photobucket.com/albums/y25...y/DSCN3126.jpg
kwikfishron 03-24-2010 08:03 AM
199 Attachment(s)
Frame a wall in front, cover and tile.
Gary in WA 03-24-2010 09:57 PM
See if your local Building Inspector will give you a courtesy call to be safe.
Be safe, Gary
KlamathMog 03-25-2010 11:10 AM
GBR-
that is a very good idea! But we already have it pretty much done.
I got a copy of the oregon building codes online. Only thing that we had to observe was no flammable material within 2" of the brick work. I put a metal beam in to reinforce the new sheetrock. Then I ground the brick flat and I mortaring hardibacker on with quickset. In the large areas I am reinforcing the cement with chicken wire. Look ssturdy, fireproof, and true.
thanks for the suggestions though!
