Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-24-2008, 10:54 AM   #1
How do you remove plaster cove molding?
our single story, detached home was built in 1956. the walls and cove molding are plaster. we would like to remove the cove molding, repair the walls as required and install a smaller MDF crown molding. my BIL used an angle grinder but said that it made a huge mess dust wise and to the walls. is there a better way?
mattedfred is offline   Reply With Quote
Old 10-25-2008, 08:39 AM   #2
bofusmosby's Avatar
I can't really answer your question, but you should know that some plaster contains asbestos. You might want to have a sample of it checked before you do any more grinding.
bofusmosby is offline   Reply With Quote
Old 10-27-2008, 05:23 PM   #3
You really need to use a good shop vacuum and respiratory protection when you do this. Tape up the room in question as tight as possible.
Ron
Old 10-28-2008, 04:48 PM   #4
regardless of the concerns over asbestos and dust, how do you remove it? i.e. recip saw, angle grinder, sledge hammer, chisel etc
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Plaster Work Still Getting Soft When Wet davidmp Painting 7 08-10-2008 11:52 AM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Cove molding: to cope or not? white29 Carpentry 24 02-11-2008 12:33 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
