How Do You Dispose Of Old, Heating Oil Barrels Attached To The Outside Of A House? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 09:15 PM   #1
How do you dispose of old, heating oil barrels attached to the outside of a house?
We are selling my parents house. In order to get an FHA loan I understand FHA will require us to remove and dispose of the old, unused for many years, oil barrels hanging on the backside of the house. How do we do this?
shortystubbs is offline   Reply With Quote
Old 04-05-2011, 09:36 PM   #2
Rewards Points: 87
Where are you located?
Are you able to get up on a ladder and do the work yourself?
George6488 is offline   Reply With Quote
Old 04-06-2011, 08:33 AM   #3
Rewards Points: 5,336
Post a photo.
Were these barrels used in lieu of an oil tank?
Do they have oil in them?
If they're empty and dry, you should be able to just throw them out or take them to a scrap metal place.
Ron
Old 04-06-2011, 10:01 AM   #4
Rewards Points: 87
Many older houses in New England used kerosene and/or heating oil for room heaters as these older houses did not have central heat. There is a good chance barrels were used for kerosene and very well maybe empty.
Climb up and check to see what is in the barrels by removing the bung at the top and using a flashlight to look inside. Also try moving the barrel to see if it feels like it has contents.
Any contents can be drained into containers for disposal. Most cities and towns offer limited hazardous waste disposal or perhaps a waste oil company would come and get your material.
The barrels must be taken down and neutralized with water and chemicals prior to disposal at a scrap yard. The scrap yard may require the top of the barrel be cut off prior to acceptance.
If this work on ladders is more than you are able to do yourself then you should call a local heating oil company who can probably provide assistance for a fee.
Post pictures and tell us where you are located if you require additional assistance.
Old 04-06-2011, 10:04 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
We had to dispose of one so we called our heating oil company.
They drained the oil into a tank on their truck, then removed the tank and took it away.
Call your local company and find out what they would charge.
Some places buy used oil to heat their their shops.
tcleve4911 is offline   Reply With Quote
Installing outdoor faucet using pex attached to outside of house. Wayne Harris Plumbing 1 02-19-2011 12:00 PM
Trouble heating house w/ Carrier Weathermaker Infinity adam_murphy HVAC 2 01-09-2011 08:51 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
Heating Retrofit in a Victorian Multi-Family House mumphis HVAC 1 09-30-2006 11:36 PM
