How Do I Renovate My 3 Season Porch? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 10:24 PM   #1
DIYFrau
glamgirrl's Avatar
Question
How do I renovate my 3 season porch?
My house has a large side porch that is currently 3 seasons...it's unheated. It came with awful faux green wood panelling mixed with brown faux panelling and a mixture of carpet & lino floor. It's in rough shape, and I'd like to redo it. The question is where to start?! The ceiling has icky acoustic tiles ( I want to put up T&G cottage grade pine) and redo the walls in tongue & groove pine as well. (The whole house is kinda cottagey).
Do I take down the ceiling first, then the wall panels? Or the other way around? I'm hoping I can add insulation to keep it warmer in the winter too...there is a duct in the basement that seems to go into this porch, but it's closed off- I might be able to get heat in there.
It has windows on 3 sides- only 2 that open, the rest are fixed (and need replacing!) My stairs to the basement are through this porch too, and it has 3 doors- one into the kitchen, one out the front of the house, and one into the back side yard. All good metal exterior doors.
Any advice for me?
glamgirrl is offline   Reply With Quote
Old 03-08-2010, 10:31 PM   #2
You need to plan on insulating the floors, walls & ceilings 1st
Unless you are going to leave it 3 season ?
But with insulation you will be able to use the area longer
So decide how much you want to do 1st
Myself I'd insulate everything
Old 03-08-2010, 10:35 PM   #3
DIYFrau
glamgirrl's Avatar
I can tell from peeking behind the loose panelling that there is some insulation-but I'm guessing not alot. So should I take down the ceiling first and insulate that and put up the t&g boards, THEN do the walls? I'm not sure what order this project should go in- without making a huge mess! I tend to do things in stages, rather than tear it all down then put it all back up...partly due to cost! LOL
Thanks,
Old 03-08-2010, 10:37 PM   #4
Heat rises, so I would do the ceiling 1st
Just make sure you wil be able to get the wall paneling off after doing the ceiling
The Following User Says Thank You to Scuba_Dave For This Useful Post:
glamgirrl (03-08-2010)
Old 03-09-2010, 08:34 PM   #5
Registered User
Rewards Points: 5,242
Walls first: http://www.explainthatstuff.com/heatinsulation.html
Be safe, Gary
Gary in WA is online now   Reply With Quote
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
How to rebuild a porch with a roof? redblotoflife Carpentry 2 11-23-2009 05:35 AM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 09:31 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
Pollen season and my new yellow porch dchaban Building & Construction 9 04-25-2008 01:18 PM
