-   -   How do I renovate my 3 season porch? (http://www.diychatroom.com/f15/how-do-i-renovate-my-3-season-porch-66342/)
glamgirrl 03-08-2010 10:24 PM
My house has a large side porch that is currently 3 seasons...it's unheated. It came with awful faux green wood panelling mixed with brown faux panelling and a mixture of carpet & lino floor. It's in rough shape, and I'd like to redo it. The question is where to start?! The ceiling has icky acoustic tiles ( I want to put up T&G cottage grade pine) and redo the walls in tongue & groove pine as well. (The whole house is kinda cottagey).
Do I take down the ceiling first, then the wall panels? Or the other way around? I'm hoping I can add insulation to keep it warmer in the winter too...there is a duct in the basement that seems to go into this porch, but it's closed off- I might be able to get heat in there.
It has windows on 3 sides- only 2 that open, the rest are fixed (and need replacing!) My stairs to the basement are through this porch too, and it has 3 doors- one into the kitchen, one out the front of the house, and one into the back side yard. All good metal exterior doors.
Any advice for me?
Scuba_Dave 03-08-2010 10:31 PM
You need to plan on insulating the floors, walls & ceilings 1st
Unless you are going to leave it 3 season ?
But with insulation you will be able to use the area longer
So decide how much you want to do 1st
Myself I'd insulate everything
glamgirrl 03-08-2010 10:35 PM
I can tell from peeking behind the loose panelling that there is some insulation-but I'm guessing not alot. So should I take down the ceiling first and insulate that and put up the t&g boards, THEN do the walls? I'm not sure what order this project should go in- without making a huge mess! I tend to do things in stages, rather than tear it all down then put it all back up...partly due to cost! LOL
Thanks,
Scuba_Dave 03-08-2010 10:37 PM
Heat rises, so I would do the ceiling 1st
Just make sure you wil be able to get the wall paneling off after doing the ceiling
Gary in WA 03-09-2010 08:34 PM
Walls first: http://www.explainthatstuff.com/heatinsulation.html
Be safe, Gary
