How Do I Improve 2nd Floor Air Flow? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 07:26 PM   #1
How do I improve 2nd floor air flow?
Problem: Our second floor is an "A" frame without an attic. We have one air return vent over our loft which connects to our large bedroom/bath and a large room over the garage. There are doors between the 3 large areas. Our bedroom in the middle gets no air flow and is hot in the summer and cold in the winter. There is one vent in each room; Our garage and room over it is partially insulated but much hotter in summer and vice versa in the fall so we use it as storage for now. Our furnace is in the basement for upflow. We have ceiling fans in each room and currently using an air conditioner for our bedroom keeping the door closed temporarily.
Question: Should I add air return vents into each room? Add another vent to blow air in to each room as well? Or add a second furnace to the second floor? Can I add more insulation in the wall under the roof?
If it were up to me, I'd just buy another house with an attic, but that's not an
traumer17 is offline   Reply With Quote
air ducts , cooling , insulation , ventilation
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 10:14 AM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
