How Do I Drill The Hole In The Wall If I Don't Know Location Of Electrical Wire - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2006, 08:01 PM   #1
How do I drill the hole in the wall if I don't know location of electrical wire
I need to hang medicine cabinet in my bathroom. There is a sconce on that wall. I can use stud finder to locate studs but how can I locateelectrical wires?
popkadurak is offline   Reply With Quote
Old 06-14-2006, 08:11 PM   #2
Oldguy
Rehabber's Avatar
Some of the better stud finders have electricity locaters in them, or buy a specialty circuit tracer
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-14-2006, 08:23 PM   #3
Will the fact that I have plaster walls affect the reading?
Old 06-14-2006, 08:51 PM   #4
renovations
Why do you need to locate the wires? Simply so that you don't cut them? Is the cabinet hung IN the wall or ON the wall. If you're simply screwing it to the wall just avoid drilling too deep. The wires should be over an inch inside the wall. Drill, put your plugs in and screw on the cab.
Bonus is offline   Reply With Quote
Old 06-14-2006, 09:22 PM   #5
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
The stud sensor with current finder will be able to penetrate the plaster.
fhivinylwindows is offline   Reply With Quote
Old 06-15-2006, 09:39 AM   #6
I don't remember the brand of stud finder I bought but it was in no way a cheap model, it does have a current finder built in but it was hit and miss through my plaster walls.
It was actually pretty useless for findind studs, and it got a very weak signal for wires.
ERIK2173 is offline   Reply With Quote
Old 06-15-2006, 12:37 PM   #7
fhi vinyl windows
Rewards Points: 150
Try Zircon. I use the Zircon videoscanner 5.5. It scans wood+metal and has a continuous ac detection. You will need to move it away from the wall a little after you detect current in order to get a better idea where the wire goes.
Old 06-15-2006, 01:21 PM   #8
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
My zircon works very well for AC detection, best stud finder I've ever used as well...
J187 is offline   Reply With Quote
Old 06-15-2006, 02:19 PM   #9
After looking it up I have one of the Zircon's I think it's the Multi Scan Pro. I basically bought the best one I could find at Lowe's since my old one told me there was a stud everywhere. The deepscan mode worked O.K. in some rooms but form my bathroom ceiling it didn't work at all.
Old 06-15-2006, 10:58 PM   #10
fhi vinyl windows
Rewards Points: 150
If you get digging around, let us know how many layers of plaster you have. You should be able to test the ac function on an extension cord with layers of scrap sheetrock over it.
Old 06-16-2006, 11:06 AM   #11
True, your walls may be thinner than mine are, with the backerboards and the plaster there is over an inch over the top of the studs in my house. Which by the way makes it very hard to buy replacement pre-hung doors.
How the wire is shielded might also have some effect on how easily you can find them.
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
dishwasher electrical wire feb Electrical 31 04-12-2008 11:04 AM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
