How Do I Do This Doorway??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 05:07 PM   #1
DIY Expert in Training!
How do I do this doorway???
Situation is that I framed in the back of my garage for a home office. The doorway goes from wood frame with new door in it to cinderblock to framing for office. To make it more difficult, I have the return air duct/soffit going across the opening. It is about 10" deep. I was thinking about getting 10" pine and building a casing like a door and nailing it in. Thoughts?
gone_fishing is offline   Reply With Quote
Old 01-25-2009, 05:11 PM   #2
the Musigician
DangerMouse's Avatar
if you're going to put up drywall, just turn the corner with it?
DM
Old 01-25-2009, 06:44 PM   #3
Remodeling Contractor
And you know that this door must be a fire door, which this one does not appear to be.
Old 01-25-2009, 07:36 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'd suggest wrapping the door way with sheetrock, or in this case, a mold/mildew rated type. It can be glued to the CMU areas.
- Build Well -
Old 01-25-2009, 08:18 PM   #5
Bob...it doesn't need to be fire as it's going from living space to living space. The new wall I put up will have the fire door installed.
Old 01-26-2009, 01:20 PM   #6
Update: Passed framing inspection with flying colors today...need 90 minute fire door...not 20. Inspector was wrong.
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 03:52 PM
Sealing a Standard Doorway seal8682 Building & Construction 5 09-06-2006 06:31 PM
constructing a hidden doorway bubblehd Building & Construction 1 10-15-2005 02:13 AM
