How Do I Attach Ceramic Tile To Ceramic Tile? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 08:35 AM   #1
how do I attach ceramic tile to ceramic tile?
I have just finished tiling my tub surround with 3x6 inch subway tile but
the ceiling is not level so there is an uneven gap between the last course
of wall tiles and the ceiling. I thought to use a ceramic cove molding to match the trim in the rest of the bathroom but what are the best materials, thinset, adhesive to use to attach ceramic tile to ceramic tile?
porchhen9 is offline   Reply With Quote
Old 07-31-2011, 10:54 AM   #2
how big is the gap?
Old 07-31-2011, 11:35 AM   #3
How do I attach ceramic to to ceramic tile?
Hi the gap isnt even all the way along the wall..It is goes from approx 12/16 to maybe 1/16 at a pinch from the corner of the end wall of the tub surround
to the outside, at the back the gap goes from about 8/16 to 14/16 along
the length. I assume the gap at the plumbing end of the surround would
probably mirror the gap at the non plumbing end. I place the level up against
the ceiling and it seems to off by about the same amount at both ends.
Old 07-31-2011, 12:02 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It's all in the planning isn't it?
You could add another row of bullnose tile on top of the top row of wall tile and push the new row up to the ceiling. This would hide the gap and sort of decorate the top of the wall at the same time.
Or you could install tile to the ceiling thereby closing the gap somewhat and that should make the remaining gap caulk-able.
There are also plastic (lightweight) decorative trims that come in six foot lengths that could be used to cover the gap maybe. You could use any of the adhesives that are sold for installing outdoor decks or cement-block retaining walls.
XXX
Old 07-31-2011, 12:04 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why is there a vertical-joint-line running up those walls?
XXX
Old 07-31-2011, 02:07 PM   #6
Hi bud...It isnt a vertical joint line...Its just marker pen. I have quite bad eyesight and I used the marker pen to mark out where to centre the tiles
for my next course. I had thought of using some kind of bull nose over the top of the existing tiles wasnt really sure what adhesive or thinset to use
as it is in a bath tub area. I found this rope twist trim that looks like it might
work, should I cope the inside corners( mitering doesnt seem to work, the
two pieces open up at the bottom when placed in the corner)
Old 07-31-2011, 02:19 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Got it! Had me goin' there for a while!
I had thought of using some kind of bull nose over the top of the existing tiles wasn't really sure what adhesive or thinset to use
I wouldn't think moisture would be a huge issue in that area. Of course there will be moisture but not enough to worry about. You could scuff the surface of the tiles that will be covered with more tile and then use PL adhesive to install the bullnose.
work, should I cope the inside corners( mitering doesn't seem to work, the
That could be done also. Same adhesive should work in both cases. The Rope Molding you are talking about...is it ceramic or plastic? Rope Molding comes in several sizes if ceramic and comes in six foot lengths if it is plastic. Either would work but I think the plastic would be more practical for this application. It's all in what you like and want to do.
I don't understand why the mitering is an issue.
XXX
Old 07-31-2011, 02:51 PM   #8
Yep maybe mitering wouldnt be a problem. The plastic rope molding sounds
a good idea.Where can you get it from? I could cut it on my compound miter saw.
Old 07-31-2011, 02:59 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I see it here at Menard's all of the time but I think I have also seen at Home Depot. Don't know about Lowe's or Builders or the others.
XXX
ceramic tile stain kivy Flooring 10 04-09-2012 06:57 AM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
ceramic tile to wood floor threshold bjs Flooring 23 11-28-2008 08:35 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
