How To Deal With Wavy Flooring - Baseboard - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 09:10 AM   #1
Rewards Points: 278
How to deal with wavy flooring - Baseboard
Aside from scribe, scribe and scribe....any tips and ricks.
I'm working with 1/2 flatstock baseboard.
The runs are way.
On one wall, I have a dip in the middle.
On another run, there are two peaks that throw the entire run off.
Not looking to do shoe moulding.
for the Wall with the 2 ends being level, and then the *dip* in the middle of the flooring....not sure what I can do just short of *filling in the gap* ---- I know it's not ideal but I don't want shoe moulding.
mobiledynamics is offline   Reply With Quote
Old 07-01-2012, 09:47 AM   #2
Rewards Points: 278
In in one corner...if I scribe high spot (corner) - the other running wall be then be *higher* in the corner.
Would it be a good idea to do a long taper - cut with a track saw on the board to ease the edge...
Old 07-01-2012, 10:35 AM   #3
Rewards Points: 12,814
Fix the floor under that area by lifting from under it, or just use 1/4 or shoe mouding would be the best ways.
mae-ling (07-01-2012)
Old 07-01-2012, 10:35 AM   #4
DIY staff
Rewards Points: 7,174
Scribing is about your only choice---I use a 4 1/2" angle grinder with two 36 grit sanding disks --stacked back to back---
You Tube---'coping with an angle grinder' for how it works--
Very fast and accurate---but messy---
Old 07-01-2012, 11:28 AM   #5
Rewards Points: 2,202
You want your corners to look right.
This usually means trimming all the base in the room.
Start with say 4" base and end up with 3" in the entire room.
Each piece is a custom fit.
Yep that is why most use shoe moulding.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
oh'mike (07-01-2012)
Old 07-01-2012, 02:17 PM   #6
bubbler's Avatar
Rewards Points: 256
Keep It Simple Sir.
If the gap were under 1/4", and I was painting it, I'd just caulk the gap.
No matter what, it's going to appear "wavy" to the naked eye because the floor has a wave to it.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 07-02-2012, 06:52 PM   #7
Haverhill Trade 1965
Depending on whether the effort is worth the results, you could try tacking the baseboard to the walls, at a height you would have to calculate from the lowest point. Use something like a router or roto zip with a straight cutting bit and use the floor as a scribe guide. You would only have to hand finish a few inches at the ends. (Just make sure you go in the direction that the router rotation pulls toward the floor. Not the Tim Allen direction.)
Duckweather is offline   Reply With Quote
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 01:31 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Baseboard install over Laminate flooring? Oxymoron Flooring 3 08-07-2010 06:50 AM
Baseboard and Radiant Flooring Dilemmas Summiteer HVAC 4 03-13-2010 07:12 AM
Flooring and Baseboard Removal hammermonkey Flooring 3 01-10-2009 07:45 PM
