Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-16-2008, 06:31 AM   #16
BUILDER / REMODELING CONT
buletbob's Avatar
How to cut styrofoam insulation
Originally Posted by Bayman View Post
Oh, I have another question with regards to nailing the furring strips to the house.......as stated earlier I am attaching the furring strips over a stuccoed house.....
I have a Bostich framing nailer and a small compressor that goes to around 90psi......now when I tried to attached the fulling strips(1 3/4 x 1 1/2) with the Nailer the nails went through the strip but not through the stucco and into the 2 x4, instead they bent up......
Any suggestions how I can solve this problem.......
Glue and steel cut nails ( masonry Nails )
Old 09-16-2008, 12:25 PM   #17
You may consider drilling through the stucco or use explosive fasteners!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Styrofoam insulation dpreznik Building & Construction 2 07-29-2008 04:56 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
