How Can I Easily Convert A French Door In My Apartment Into A Normal Door? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 09:46 PM   #1
How can I easily convert a french door in my apartment into a normal door?
This is a little bit of an odd question, but I live in NYC and the apartment we live in has a study that we are planning to use as a bedroom. The only problem is that the doors are french style (with 15 small windows) and we obviously would like to have privacy in the bedroom. Any ideas to seal off the windows or any other solutions to turn them into "normal" doors? We live in an apartment building so we are not going to uninstall the doors and put in regular ones. How do I cover up the windows?
neelcv is offline   Reply With Quote
Old 09-16-2010, 11:12 PM   #2
Rewards Points: 56
There are window films that big boxes and home centers carry, which could be used. They come in semi-transparent, opaque, patterns, basically whatever you want, can be cut to size, dampened in the sink, and pressed to the glass. They are held, basically, by static, I guess, because they stay in place well, but can easily be peeled off. Another option, although it would require some minor repair when removed, depending on the type of door, might be rods at the tops and bottoms of the panes, with curtains. You should be able to fasten them up with relatively small brads or screws, and, again, depending on the type of door, fill the holes with a paint or stain crayon when you later remove them.
Old 09-17-2010, 12:22 AM   #3
Registered User
Rewards Points: 5,236
Inform your landlord of the added bedroom usage as he/she is liable. It needs to have an egress window and be a minimum floor square footage size and possibly other requirements as well: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
Gary
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
Turning an existing solid core interior door into a french one? laurajeany Carpentry 13 11-29-2009 07:41 AM
French door installation dale_jr. Carpentry 6 07-23-2006 06:24 PM
Convert two door garage to a one door garage ConstantChange Remodeling 4 05-31-2006 10:31 AM
french patio door replacement nasa-hvac Building & Construction 2 06-15-2005 09:49 AM
