How To Build A Wall Around A Garage Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 01:24 PM   #1
how to build a wall around a garage door
Hello, I have a two car garage that i am trying to make a couple of rooms out of however i still need the garage door to go up and down. so for half of the room i do not have support that I can use for the ceiling do to the garage door when it is open. can someone please help me....
MargaretPolendo is offline   Reply With Quote
Old 03-01-2012, 02:39 PM   #2
A little more info required such as proposed room sizes and a description of the layout. Can you explain why its necessary to maintain the functioning of the garage door(s)?
Marvel is offline   Reply With Quote
Old 03-01-2012, 03:39 PM   #3
In most typical garage door and opener installations nothing projects higher then the opener rail.
On a few projects I've seen where they've framed above the door.....they add approx 2" from the top of the opener rail for the rough frame and then cripples or tie wire from that to the existing ceiling to support the framing.
Behind the track.....a simple bulkhead is typical.
If you're trying to get the door above the ceiling.....a bit harder to explain because it depends on the width and height of the doors.
I've seen it done but it requires a lot of planning before even installing the garage door!
Doorman54 is offline   Reply With Quote
replacing a garage door with a wall and window stewart7 Building & Construction 10 05-15-2011 02:01 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
cutting out foundation wall for patio door lfunk11 Building & Construction 9 03-27-2011 10:55 PM
Genie Garage Door Opener - wall switch won't control LIGHT cody21 General DIY Discussions 3 12-10-2010 05:36 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
