How To Build Pantry Shelves - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 5 Post By connsu
Old 12-05-2016, 10:17 AM   #1
Rewards Points: 4
How to build pantry shelves
I have a space 52" wide and 36" deep and I would like to install a U shaped pantry shelving unit. I need suggestions about the best way to support the shelves and the best material to use. I prefer wood. Thanks.
connsu is offline   Reply With Quote
Old 12-05-2016, 12:38 PM   #2
Rewards Points: 2,818
Re: How to build pantry shelves
How fancy would you like it?
A simple shelf would consist of 2X4 studding, at each corner, with @x4 rails every foot or so along the height, as supports for 1X12 clear pine shelving.
Then there is the more expensive pre made brackets, and shelving in most BOX stores, on up to a custom made Cabinet shop design.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
connsu (12-05-2016)
Old 12-09-2016, 07:57 AM   #3
Rewards Points: 954
Pantry items can be heavy and even reinforced ply or board can sag unless you reinforce with hard wood 2" or wider.
I would put in 48" wide metal shelving and go local and see if extra shelves can be bought. Some cheap metal units are good for extra shelves. I mean buy 2 and use the extra shelves for short stuff like the cans. Then line the shelf with 1/4" ply if you like. Use the extra space for mops, etc.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
connsu (01-18-2017)
Old 12-21-2016, 02:59 AM   #4
hkstroud's Avatar
Rewards Points: 2,080
How about this.
Edge of plywood can be finished with iron on edge banding.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
connsu (01-18-2017)
Old 12-21-2016, 10:24 AM   #5
Gymschu's Avatar
Rewards Points: 1,024
Originally Posted by bellfort View Post
Wood is a nice option but make sure you go with the right one in choosing it and take some help from experts..and also there are cabinets that can be made well..
Huh?
Giving us your general location helps us better help you!
The Following User Says Thank You to Gymschu For This Useful Post:
connsu (01-18-2017)
Old 12-24-2016, 12:57 PM   #6
Rewards Points: 30
I made some shelves in my dining room closet by screwing 1X4’s, across the back and sides of the wall, on to the studs. I cut 1X12 pine boards to length, than placing a 1X2 on the front edge for a finished look. Then I painted the shelves to match the wall paint color.
tramp is offline   Reply With Quote
The Following User Says Thank You to tramp For This Useful Post:
connsu (01-18-2017)
Old 12-25-2016, 03:25 PM   #7
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Here's a good YouTube video on building pantry shelves:
This one also gives some good tips (tools, finding the studs when your stud finder isn't working properly). I wouldn't make the shelves any deeper than 12", much more than that and you'll be moving everything in front to find stuff in the back.
ghostlyvision is offline   Reply With Quote
The Following User Says Thank You to ghostlyvision For This Useful Post:
connsu (01-18-2017)
Old 01-18-2017, 08:33 PM   #8
Rewards Points: 4
Thanks for all of the suggestions. Here is the finished product! My husband loves it!
Custom Rev-A-Shelf pantry pullout zzty00 Kitchen & Bath Remodeling 3 11-06-2013 11:07 PM
Building Shelves for cat set Carpentry 7 02-29-2012 03:59 PM
Pantry Shelves Spacing Scully Carpentry 3 02-15-2012 03:58 PM
Pantry Shelves...What to Use? Scully Carpentry 12 02-13-2012 07:56 PM
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General DIY Discussions 10 12-07-2011 12:10 PM
