How To Apply Wall Texture? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 11:28 PM   #1
How to apply wall texture?
I got a hopper gun, air compressor and mud that I am mixing with water. The walls are finnaly ready for the texture to go on. Some of the walls have a slight knockdown texture the others have pretty much nothing.
I was planning on going with a knockdown texture but now think orange peel would look better. I am doing the ceiling and walls. What texture is modern and most popular in new constructions?
Finnaly I diluted the mud, poured in the hopper and shot away, varrying between 25-30 psi. What came out was nothing like orange peel or knockdown (after knocking down).
What should I be doing?
amdspitfire is offline   Reply With Quote
Old 02-05-2008, 06:55 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by amdspitfire View Post
.....I was planning on going with a knockdown texture but now think orange peel would look better. I am doing the ceiling and walls. What texture is modern and most popular in new constructions?
That depends on the region of the country you are in.
I would not know for certain, but would guess to say this: Florida region: Knockdown. Mid. and West: Orange peel.
Really, I am in new england, and tradition reigns here = smooth.
Finnaly I diluted the mud, poured in the hopper and shot away, varrying between 25-30 psi. What came out was nothing like orange peel or knockdown (after knocking down). What should I be doing?
First off, knockdown and orange peel are completely different in their mixtures, application, and methods of completion.
For Orange Peel, you need two things:
1.) Proper nozzle size (Very small spray)
2.) Very diluted compound mix. Almost watery.
Do test sprays onto scrap or junk surfaces. When you get the mix right, make sure that if you allow it to sit for over 1/2 hour, stir it up (mix it) before using again.
FWIW: We always lightly sand the texture after it dries. A light, even sanding removes any globs or specs, and "tones-out" the surface.
- Build Well -
Old 02-05-2008, 11:45 AM   #3
Would orange peel be ok on the ceiling? Will orange peel cover a wall with slight pre-existing knockdown?
I think I was using the middle size nozzle when I tried it out yesterday. The compound mix was pretty much like pancake batter and the output seemed too much. 25psi about right for orange peel?
Old 02-05-2008, 04:39 PM   #4
Yes.
No, it will not. You must get the surface as smooth as if you were planning on the walls not receiving any texture.
Your air pressure should be fine. The key factor is the mixture consistency, and the nozzle size.
- Build Well -
Old 02-05-2008, 05:07 PM   #5
AWBC is correct. I live in the Pacific Northwest. Orange peel texture is the trend now and has been for several years.
I have done both types of texture. As a good, but still amateur drywaller, I highly recommend using orange peel. It is far easier.
When I did knock-down texture, I sprayed the texture on and used a 30" knife to make the knock-down effect. The secret is to get the texture to the perfect consistency and wait until it is dry, but not too dry, enough to knock-down without it moving with the knife. Also, you don't want lumps in the texture. Otherwise, you will get what I call "skid marks" as a result. These are small furrows caused by dragging the lump.
In my opinion, both types of texture look good. They will cover many blemishes, but don't expect them to make a bad taping job look perfect.
Good luck!
Handyman50 is offline   Reply With Quote
Old 02-07-2008, 01:03 AM   #6
Shooting orange peel like a pro now :D
The biggest problem I am experiencing is clumping when mixing the compound. I add water very slowly and try to get it mixed well before diluting it more. What other advice do you guys have for avoiding clumps and mixing this stuff better?
Old 02-07-2008, 08:44 AM   #7
Try putting the water in first,then add compound.Works for me...............
mark942 is offline   Reply With Quote
Old 02-07-2008, 08:49 AM   #8
We also, always add the water first when mixing...
- Build Well -
Old 02-07-2008, 12:17 PM   #9
Will give it a try, thanks guys!
Old 02-08-2008, 11:22 AM   #10
Worked a lot better starting with the water first. Thank you very much for the great information.
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Removing Texture From Interior Wall JustWondering Remodeling 3 05-28-2007 06:56 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
